E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
blade 400 pitch curves
Old 01-25-2009, 11:25 AM
hrdcoreglf
Default blade 400 pitch curves
Looking for in between pitch curves for blade 400. I have just removed training gear and would like pitch settings between the newbie settings and factory settings. The newbie settings are a little unresponsive for outdoor flying and I am not flying 3D so I don't need to have a large negative pitch below half stick.
Old 01-25-2009, 11:41 AM
lbarnes
Default RE: blade 400 pitch curves
Got these setting off a great website http://www.slyster.com/heli/.
*** Beginner settings ***
! For hovering and basic flight only !
Cyclic & Collective
JR DS285MG servos
Stock blades and paddles
Stock motor w/ stock pinion, gears and pulleys
Aileron and elevator at 90% D/R and 5%-10% expo.
Pitch normal(1) L-40%, 2-45%, 3-50%, 4-65%, H-80% (-2/-1/0/3/6).
Pitch normal(2) L-40%, 2-45%, 3-50%, 4-67.5%, H-85% (-2/-1/0/3.5/7).
Pitch normal(3) L-40%, 2-45%, 3-50%, 4-69%, H-87.5% (-2/-1/0/3.75/7.5).
-> Pitch normal(4) L-35%, 2-42.5%, 3-50%, 4-70%, H-90% (-3/-1.5/0/4/8).
Throttle normal(1) L-0%, 2-33.5%, 3-50%, 4-65%, 5-80%.
Throttle normal(2) L-0%, 2-33.5%, 3-50%, 4-67.5%, 5-85%.
Throttle normal(3) L-0%, 2-33.5%, 3-50%, 4-69%, 5-87.5%.
-> Throttle normal(4) L-0%, 2-25%, 3-50%, 4-70%, H-90%.
Pitch throttle hold L-35%, 2-42.5%, 3-50%, 4-75%, 5-100% (-3/-1.5/0/5/10).
Throttle throttle hold at 0%.
Tail
Logictech LTG-2100T gyro in Logictech servo mode
Logictech LTS-3100G servo
Ball end on 10 mm
Stock blades
Rudder ATV at 125% left/right.
Rudder D/R at 70%-90% and 10%-15% expo.
Tx gyro gain at 76.5% (77.5% max, approx. 65% min).
Gyro rotate rate at LED no. 1.
ESC
Align RCE-BL35G 35A Brushless ESC (Governor Mode) w/ built-in 5V BEC
1-Brake: 1 Brake disabled
2-Electronic Timing: 2 Mid-timing
3-Battery Protection: 1 High voltage protection
4-Aircraft: 2 Helicopter 1 (soft start)
5-Throttle Response Speed: 3 Quick speed
Sly's slow (easiest on the nerves)
T 00-20-30-40-50
P 40-45-50-75-100
Sly's med (good slow park flying)
T 00-40-50-60-70
P 40-45-50-75-100
Sly's fast (Good for fast park flying)
T 00-60-70-80-90
P 40-45-50-75-100
Old 01-25-2009, 11:42 AM
Carljw
I set mine to 42 45 50 75 100 and it comes down nice and easy
Old 01-25-2009, 05:55 PM
Wolfpackin
Wolfpackin's Avatar
IMO, you really shouldn't alter the pitch settings.
Use 40-45-50-75-100 Normal, 0-25-50-75-100 Idle-up or something very, very close.
I would also leave the throttle curves as stock or higher.
I use 0-50-80-90-100 for Normal (Finless' recommended curve) and 100-90-80-90-100 for Idle-up.
If you want to make the heli less sensitive reduce Dual Rates, add Expo or reduce the values in the Swash Mix menu.
