CX3 Recall
RE: CX3 Recall
Interesting information since I am having trouble flying my CX3, toilet bowl effect, cannot hover without extreme corrections, etc. But I called HH and they have stated there is no recall for the CX3. Maybe the LHS is doing something on their own?
RE: CX3 Recall
Hey Hank,
Since we are all talking about the CX3 and how IT DOES NOT FLY well, what have been your problems?
The one I fly is tail heavy and wants to fall backwards. The horizontal stabilizer was crooked from the factory and has a white rubber washer under it to make it level. I can take a CX2 and fly circles around the CX3, they just simply dont handle the same at! at least for me. I think my owned aircraft below speaks to my ability to handle the CX3.
JPEE
JPEE
RE: CX3 Recall
The only thing they said was to check the body. From then going from the hot to the cold some of them are cracking That is it. Nothing else to report.
My Feedback: (16)
RE: CX3 Recall
FYI,I just got off the phone with Horizon Hobby product support and the Blade CX3 has NOT been recalled according to him. He did state that the dealers were told to check their shipments to see if the bodys were damaged. That has been the only issue as far as Horizon contacting Dealers. I too had a small crack in the body of mine which Horizon has already placed an order for me to get a replacement. Horizon has always had great customer service which is why I am a long time buyer. He also told me that the CP Pro 2 has just been on delay while they look to get a little more life out of the stock high power brushed motor. I love my CX3!!!
CA
RE: CX3 Recall
ORIGINAL: 704hank
That is why they have been recalled. That is what they told me.
I don't Think they would tell me this if it was not true!![:-]
Hank
Hank
NC
RE: CX3 Recall
ORIGINAL: edblaine
is going On!![:@]
Hank
CA
RE: CX3 Recall
ORIGINAL: 704hank
This is what they told me! I am going back Sat, to see what
is going On!![:@]
Hank
ORIGINAL: edblaine
is going On!![:@]
Hank
IL
RE: CX3 Recall
I was the first person to pick up a CX3 from the LHS and probably one of the first people on here that flew one. Mine has had issues since day one.
My tail assembly is crooked. This is a known issue by E-Flite as other CX3s I have seen have a shim under the left side of the tail to straighten it out.
My CX3 has random tail jerks. Not gyro twitching, but jerks. It is worse with a fresh battery and happens more often when the gyro gain is set higher. I can reduce the frequency of the jerking by turning gain down but at the expense of tail control and heading hold.
The body on my CX3 is also ripped near the front landing gear. I though I had done this taking the body off to install the heat sink but now it sounds like it may have been this way out of the box.
RE: CX3 Recall
I thought the body cracked in my van. Oh well, a new body would be nice. What's best, call my LHS? or HH? This is my first heli and was aware of the tail twitching. Hopefully there is a fix to it.
RE: CX3 Recall
I went to my LHS today to see what was up with mine(I.E. toilet bowl and tail twitch) and they said that I should beleave what I see on the internet. They are suppost to fly that way do to the wash effect of unsteady air. I think they didn't want to stand behind something they sold me after I spend close to 400 in one week from them. Going to call HH Monday to see what's the deal. It now wants to tip over when I throttle up.
CA
RE: CX3 Recall
ORIGINAL: gravey86
You know a percentage of people that work at hobby stores have no common sense, have an IQ lower than a monkey and are confused by the simple fact why they were born! I went into a hobby store once and asked, "do you have a high performance compact nebulizer for my nitro engine", he replied you don't need one of those! [sm=lol.gif]
RE: CX3 Recall
The kicker was he explained that the body on the cx3 was cosmedic and that my crooked boom and tail had no effect to my problem. He said that on the Cx2's ppl were taking the body off and flying them. Huh, I guess I should take my body off and see if that helps pisses me off. Is there someone at HH that I should talk to that someone here has already delt with?
CA
RE: CX3 Recall
ORIGINAL: gravey86
RE: CX3 Recall
the heli flys good its the stock landing skids that throw it off and easilly break on rough landings
i replaced mine with the trex 250 landing gear and it worked like a charm.
NY
RE: CX3 Recall
So guys have the cx3s realy been recalled? Myn flys great except for the small tail jerks once and a while. Should I worry about taking it back. I was goint to install the sea hawk body but don't want to yet if there realy is a recall thanks guys.
RE: CX3 Recall
since i am a newbie, this may sound dumb. I noticed the landing gear seemed really weak and helped crack the fuselage. I took two average sized rubberbands and attached one of them to the front left to the rear right steps on the skids, and the other band on the front right step to the rear left step on the skids. They were still somewhat loose when attached, but when it landed a bit hard the shock was absorbed by the skids and rubberbands.
Maybe this helps on the 'weak skid' issue. By the way, I learned not to fly the CX3 in light wind. :-0
CT
RE: CX3 Recall
Mine was cracked too. But as soon as I brought it up to the counter, the owner said he wanted to open the box and look at it first. He said they way they are packed the canopies have been cracking. When he saw the damage, he said he had new canopies on order already and that he would give me one. I'm having flight issues too but that is probably because I'm a noob and crashed it a few times...
