E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
DX6i settings for the Blade 400
Reply
Old 02-26-2009, 08:54 PM
Barney de
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DX6i settings for the Blade 400
I inadvertently 'reset' my DX6i, erasing the Blade 400 settings. I subsequently located the factory settings at: http://h1071118.hobbyshopnow.com/Pro...400RTFHeli.pdf
The setup was straight forward with two exceptions:
1. DR & Expo shows correct settings as:
AILE 1 90%
ELEV 1 90%
The 90% was easy to set but I couldn't change the 0 to 1, so I have:
AILE 0 90%
ELEV 0 90%
2. TRAVEL ADJ wants RUDD <-90% ->90%
There is only one number to adjust on the menu, so am I safe to assume that setting 90% at the one occasion is all that's required.
While I assume the TRAVEL ADJ is ok, I am concerned about the 0 vs 1 difference I can't resolve on D\R & EXPO.
Advice greatly appreciated.
Barney de is offline
Old 02-26-2009, 09:06 PM
9sec240
9sec240's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DX6i settings for the Blade 400
Flipping the dual rate switches for both AIL and ELE will allow you to set rate 1. You can set separate rates for 0 and 1 just like your normal / stunt switch.
Rudder travel adjust is changed by moving the stick in the direction you want to adjust.
9sec240 is offline
Old 02-26-2009, 09:52 PM
bad400
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
d/r & expo
by flipping the ail d/r switch above the right stick you`ll see it change in the d/r expo window
mine is (0) 100% inh
(1) 90% +20
by flipping the elev d/r switch above left stick you`ll see it change in the same window
(1) 90% +10
by flipping the rudd d/r switch on the front right above the throttle hold switch you`ll see it change in the same window
(1) 100% inh
all switch`s act like the sticks in the travel adjust window. you have to move each control in both direction to acheave the same values for both direction`s
bad400 is offline
Old 03-20-2009, 11:54 AM
jimmanyk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i found today theres a video of the "new/revised" settings at http://www.horizonhobby.com/Articles...ArticleID=1907 and also the manual for the pnp version which has the settings
Quote:
ORIGINAL: Barney de
AILE 1 90%
ELEV 1 90%
AILE 0 90%
ELEV 0 90%
jimmanyk is offline
Reply
Display Modes
