G110, Blade CP
AB, CANADA
G110, Blade CP
Help!
I picked up a G110 today, and Im not sure where to plug each plug in, one plug has a yellow wire, other plug has three wires (black, red and orange).
Probably a stupid question but HELP!!!!
al
al
RE: G110, Blade CP
Your tail servo plugs into your gyro, the (black, red and orange) wire plugs into your rudder channel on your receiver and the yellow wire is for your remote gain (it plugs into your receiver to).
MI
RE: G110, Blade CP
ORIGINAL: albramley
Help!
al
Help!
al
the singal yellow wire goes the the gear channel.
the yellow wire is the remote gain control.
waite your heli has a tail motor drive rotor not a servo/belt setup right?
the tail motor plugs into the gyro and the gyro plugs into that channel on the reciever.
if you have a open channel that can be controled from the radio then you can use it for the gyro gain/yellow wire
