CX2: Do you have to cut the flybar to remove the rubber tip?
TX
RE: CX2: Do you have to cut the flybar to remove the rubber tip?
No. You slide the rubber-covered end weight unit in from the end of the shaft where you can see the hook. You then turn the unit 90 degrees to allign it with the other slot in the rubber cover and slide the weight off. Typcially, the brass weight will slide out of the rubber cover on its way out.
Mack
Mack
