CX2 oscillation issue
I am new to RC and was unable to find info using searches. I had a tipover crash when the training gear clipped furniture on a landing. Damage was cracked upper blade and sheared pins on lower rotor head. Once I replaced all blades and the lower rotor head, I test flew heli. After significantly adjusting trim, I got it hovering with little input. When I applied some rudder to correct a slight yaw, I noticed after releasing the stick there was a yaw oscillation that took 1-2 secs to dampen down. It was repeated every time I applied any rudder input. The heli would stabilizes after few seconds. Because of the oscillation, I am guessing it is electronics, maybe gyro related. Any help would be appreciated, thank you.
Jon
Jon
