Blade 400 pitch
My Feedback: (34)
Blade 400 pitch
Okay I am trying to set my pitch but I can't get my low and high equal.....the blades are 0 at mid stick, -4 at low and 9 at high....i have leveled the swash plate as best I can but how do I get my low and high equal?
NE
RE: Blade 400 pitch
Your swashplate probably isn't centered. You will need to adjust the outer links equally on the swashplate in the direction of the negative pitch. You will need to redo all the links in the head to get 0 degrees of pitch at center stick. Once both pitches are equal you can adjust the swashmix for pitch to get more pitch for both pos and neg pitch.
Nick
Nick
PA
RE: Blade 400 pitch
Along with what Nick has posted, make sure your servo arms are at 90 degrees when the sticks and trims are centered. By what you posted, you need to lower your swash a little (adjust all 3 ball links the same amount) and then readjust for zero degrees at mid throttle stick. Keep us posted.
PA
RE: Blade 400 pitch
You can if you'd like. I don't own one and honestly don't see the need for one. You can get it very close by eye and then fine tune it once you are hovering and see which way the heli wants to drift, usually it isn't much of a change.
Many guys like them so its more a personal decision.
NE
RE: Blade 400 pitch
ORIGINAL: ads8525
I will give it a try tonight when I get home...thanks for the input
Should I invest in a swash leveler?
Nick
CA
RE: Blade 400 pitch
I just use an Allen wrench zip tied to the main-shaft (with the head off) for leveling the swash...Why buy a tool when you simply want it 90 degrees to the MS.
RE: Blade 400 pitch
ORIGINAL: Wnuk
I have never used a tool or Allen wrench while setting up heads except once. I set up my heads by eye and make final adjustments after a hover. I did use a tool on my 500 T-REX once but found it was not madatory. So for my 400-500 and 600E, they are all done by eye and final trims after a hover. I might add that after I did use the tool on the 500 and it was dead nuts level! it still needed some tiny trim after the hover. DON'T misunderstand........ you can't go wrong using one, they are just the end-all.
JPEE
My Feedback: (34)
RE: Blade 400 pitch
ORIGINAL: evdreamer
Nick
Nick
