MCX FlyBar from factory unbalanced.Why?
Hello Everyone,
Sorry, I need to clarify my question
MCX s300....Struggling with Toilet Bowl Effect
Question: Why is "Factory Fresh" Flybar heavier on one side than the other? Is it supposed to be balanced?
GA
RE: MCX FlyBar from factory unbalanced.Why?
I have found not only on my MCX S300 but my standard MCX and even my MSR that adjusting the trim just right makes a big difference on the toilet bowel affect. I am using a DX6i on all of mine and one or two clicks on the trim can make a big affect on this affect. Mostly on your elevator trim.
CA
How did you attempt to check the balance of the flybar?
It's just a cheap molded piece of plastic very easy for it to be unbalanced.
I find TBE to be somewhat of a myth on these micro helis.. Often caused by the user's stick inputs..
No need to. Heavy side always tilts down every time I land Heli.
Member said:
GA
I agree on these little helicopters the TBE affect is real. But I all so have found you might think you have the trim set and just a little one way or the others makes a BIG difference. I have well over 200 flights on my micro E-flites and so far have always been able to trim the TBE out. This is just my micro fleet. I have a total of 11 helicopters.
ORIGINAL: klaze
That screw needs to be perfectly adjusted with very little play in the flybar
CA
[quote]ORIGINAL: Mad Town
Member said:
CA
ORIGINAL: geoffg1
Loosen off the top screw and you will know TBE exists.
Loosening the screw wouldn't cause TBE tightening it so the flybar can't move freely *could* cause it.
