idle up mode
MD
idle up mode
hi. i have a blade sr and i have been reading that it flies much better in idle up mode. i have never done it before and was wondering if you guys can tell me the right process for getting it into this mode. like do i just put it in idle up before i take off? or is it something i do while already flying? can you please tell me how with some detail? i don't want to mess up my heli trying something new. thanks alot
NE
RE: idle up mode
It depends if your transmitter has a throttle hold and the ESC has a good soft start.
If they don't you flip into idle up while in a hover. Then you go into normal mode in a hover and land when you are done.
If they do you can flip into idle up before you take off. First you would turn on the throttle hold. Then plug the battery in. Flip into idle up. Move the pitch to zero degrees. Then turn off the throttle hold and wait for the blades to spool up.
Nick
Nick
NJ
RE: idle up mode
if your transmitter does not have throttle hold your going to have to get it into a hover then flip it in idle up ....then when you wanna land get it back in a hover flip off idle up and then land.
The reason it runs better in idle up is cause the head speed is higher and more consistent.
