blade 450 canopy on blade 400??
hey i have a blade 400 and i was just wondering if you can mount the blade 450's canopy with the 400 or even the blade 450 canopy mounts?
i was wondering because the 450 used 2200mah batteries and i cant fit that size battery into the stock 400 canopy, that's why i had to get a trex 450 one! after the release of the blade 450 i was wonderinf if it would work since i kinda like the shape better thanks |
RE: blade 450 canopy on blade 400??
oh i just realized the blade 450 wont be released until late april!.... sorry. [&o];)
but what do you guys think still? will it be possible it will be an exact mount on? or will i need to "customize" it to fit? thanks :D |
anyone have an answer yet??
the 450 is the 400 just better supposedly better electronics its all the same a few changes like the 1 peice skids vs seperate tubes and struts on 400 this being said yes it should fit right on worse case scenario u have to cut out 2 long holes for the canopy grommets to line up
and btw i have a 400 and i fit 2200's under that canopy np its tight but they fit
Ok, thank you. I really dont like the Blade 400 canopies, I personally like the Blade 450s better. I think I might try one of those. Thanks!
