Blade SR / Channel 5 and the "Yellow Wire"
Ok guys, I have heard both. I have heard you can connect the wire to channel 5 using the stock transmitter for the Blade SRand adjust the gain of the gyro.
Other people say that without a "digital" radio, you can not adjust it with the stock transmitter. So, two questions: 1. Can you or can you not adjust the gain with the stock transmitter on channel 5? 2. If you can do remote adjustment of the gyro gain, can you do it "on the fly" or do you have to power down the gyro each time to set the new setting, just like you have to when you manually adjust the gain on the pot? Thanks in advance, C |
RE: Blade SR / Channel 5 and the
1. YES. My SR and my CPP2 are both controlled via the TX.
2. Yes you can do it on the fly. No need to power down. You also do not need to power down when adjusting the pot on the gyro. You do however have to power down when making changes to the pot on the proportional mixer. |
Your remote gain will not work with the stock tx. You need a DX6I or a DX7.
And here lies my problem. Some will tell you yes, some will tell you no. I thought Iread in the manual that you must power down and power back up for any changes to the gyro gain pot to take effect.
I will go back and re-read to make sure. Until then, is there an expert in the house who can settle this ? C |
As far as adjusting the gain, I would say no power down required. The reason I say this is that I adjust the gain through my DX6I on the fly without powering down. I have down a lot of reading on this as well and still haven't found anything saying that you have to power down. All you are doing is adjusting the sensitivity of the gyro. Unless your instructions says that you need to power down to reset, then the answer is no.
I believe 9sec240 is correct. Reading the manual it's not hooked up by default and it doesn't say anything about hooking it up. But, the stock TX has a ch5 knob which you should be able to use to control the gain by hooking the gyro up to the gear channel of the receiver.
You have to power down to adjust the proportional, not the gain. |
Well, Itried hooking up the wire last night and it did not go well.
First, Ihooked up the yellow wire to the logical place, the far left (when viewed from the tail rotor) pin on the AR6100. Nothing happened, it flew like normal. Then, Irealized that by reading the pin labels, the far left is AUX1, GEARis buried between two others to the right. So, Ihooked it up there and flew again. Still flew the same no matter what Idid with Channel 5 knob. So, Iunhooked the yellow wire and now all I get is a hard left hand spin. So, Iwent back and checked all the connections and they are all hooked up, but it still spins violently. Any chance that by hooking up the wire Ifried the Gyro or the tail motor?\ So for me, the answer is simple, with the stock trans and the Blade SR, you can not adjust gain remotely. You need to use the pot, which was working fine for me until NOW!! C |
I personally would not have even tried. If it was possible to do it, they would've done it at the factory.
I don't see how you could have possibly fried the gyro, but who knows. Maybe the tail motor or esc though. I'm guessing by spinning left you mean counter-clockwise looking down from above (as if you were holding the rudder to the left). That's an indication that the tail rotor isn't doing anything.
Did you connect it with the yellow wire towards the top or the bottom? Are you sure you lined up the connector with all the pins? |
G,
The yellow wire was towards the bottom. But why would it not return to normal when Idisconnected it? Ihave a new tail motor coming from RCBoca, not looking forward to changing that and soldering iton, but hopefully that is all it is. c |
ORIGINAL: Solman Your remote gain will not work with the stock tx. You need a DX6I or a DX7. You are wrong. ORIGINAL: c9403 Well, I tried hooking up the wire last night and it did not go well. First, I hooked up the yellow wire to the logical place, the far left (when viewed from the tail rotor) pin on the AR6100. Nothing happened, it flew like normal. Then, I realized that by reading the pin labels, the far left is AUX 1, GEAR is buried between two others to the right. So, I hooked it up there and flew again. Still flew the same no matter what I did with Channel 5 knob. So, I unhooked the yellow wire and now all I get is a hard left hand spin. So, I went back and checked all the connections and they are all hooked up, but it still spins violently. Any chance that by hooking up the wire I fried the Gyro or the tail motor?\ So for me, the answer is simple, with the stock trans and the Blade SR, you can not adjust gain remotely. You need to use the pot, which was working fine for me until NOW!! C It would be impossible for you to hurt the gyro or tail servo by plugging the gain plug in wrong in any spot. Double check the connections at the RX. It sounds like maybe you unplugged the gyro when you pulled the gain plug out. If that is not the issue, I would suggest looking around the wiring a bit more. Make sure you did not accidentally cut a wire while removing zip ties or pulled a pin out of a connector. |
ORIGINAL: Solman I personally would not have even tried. If it was possible to do it, they would've done it at the factory. I have remote gain running on both my CPP2s, My BSR and my CX3. Every one of them come with the remote gain plug unplugged. |
9sec240,
You seem to be the most knowledgeable on this subject. Iam checking my wireingand all looks normal. In looking at the diagram for the AR6100, it goes from left to right (when viewed top down from the tail) 1. Battery 2. Throttle 3. Aeileron 4. Elevator 5. Rudder 6. Gear 7. Aux 1 Everything is plugged in and no wires appear cut or broken. Iget all other servos working with stick input, but Inever hear the tail motor do anything other than spin up at a constant speed. Which pin / plug would be unplugged and not letting the tail motor do it's job? So, is it possible that the tail motor just went out? Ihave a new tail motor on order, but not looking forward to soldering that in, but can do it. Can you re-use the heat sink on the tail or do you have to order a new one for each new tail motor? Any other ideas to try to get her back in the air? Thanks in advance for the help. Ifeel like a fool! Chris |
Did you make sure that your connectors are plugged in the right direction? It doesn't seem like your tail motor is bad if it is spinning and it worked before. The connectors that will affect your tail motor is your rudder/receiver, rudder/gyro, gyro/receiver, and the tail motor going to the esc. Make sure the yellow wires are all on the same side on the receiver. BTW, do you have anything plugged into gear right now?
ORIGINAL: 9sec240 ORIGINAL: Solman Your remote gain will not work with the stock tx. You need a DX6I or a DX7. You are wrong. |
I used channel five for Gyro gain on the stock TX successfully also. But I've moved on to a DX6i because of the programing ability.<div>
</div><div>9sec probably is the most knowledgeable and experienced with how it works and flying. His advice has never lead me astray.</div><div> <div> </div><div> </div></div> |
ORIGINAL: c9403 G, The yellow wire was towards the bottom. But why would it not return to normal when I disconnected it? I have a new tail motor coming from RC Boca, not looking forward to changing that and soldering it on, but hopefully that is all it is. c Plugging it in upside down will make it not respond to your control, that's why you didn't notice any change when you turned the knob. It should have returned to normal when you unplugged it, something else must have happened. The only way I can imagine anything was damaged is if the gyro interpreted the wrong connection as signaling maximum gain which might have over worked the esc or motor burning it out. I think that is very unlikely though since you probably would have noticed bad tail wag and I don't think it would be behaving as it is now. It could be possible that the tail motor is worn to the point where it can still spin but just isn't strong enough. See if you can bring the throttle up so that the tail rotor is spinning but the heli is still stationary on the ground and move the rudder to see if the tail speeds up and slows down. That will tell you if the tail is responding at all. If the tail is responding but just can't keep the heli from spinning counter clockwise, I would replace the motor and see if that helps. ORIGINAL: Solman So you are telling me that you can use the remote gain with a stock transmitter for the SR, eh? Please explain to me how you would do that with a <span class=''Apple-style-span'' style=''font-family: Verdana, Arial, sans-serif; font-size: medium; ''><span class=''Apple-style-span'' style=''font-family: Arial, Verdana, sans-serif; font-size: 12px; ''>HP6DSM. </span> </span> |
If there is no percentage on it, how would you know where you are at on the gain and why would you? On my remote, I know exactly what percentage I am at.
Solman,
When Ifirst started this venture, I was looking to find that fine line where the tail wag was almost gone, but I still had good heading lock / control. If you watch the video on youtube, that guy says that you set the Channel 5 knob in the center at the 12 o'clock position. If you turn to the left, you go into HH mode and it gets progressively stronger, if you go to the right, you get RATEmode, same thing. (or vice versa) Iwas just tired of trying to lightly adjust the pot on the gyro and thought that using the transmitter made more sense. Now,Ihave a mess. Iam truly hoping that it is simply my tail motor that is out.I have heard others say that their motors wore out that quick, so hopefully when my new tail motor gets here Saturday or Monday, she will be back in the air. Chris ORIGINAL: Solman If there is no percentage on it, how would you know where you are at on the gain and why would you? On my remote, I know exactly what percentage I am at. |
Solman,
Yep, all connections oriented the same way and tight. Nothing plugged into gear right now. The tail motor will spin up, but after about 30% throttle, the tail quits holding and the spin to the left starts. That is leading me towards a used up tail motor. BTW, what goes "bad" in the tail motor? Since everyone says it is not "brushless", Iam assuming the brushes wear down?Or is there some other electronic gizmo inside? Iknow that on my MSR, Ihave done 3 tail motors so far, and Ifly that heli daily!!! Chris ORIGINAL: Solman Did you make sure that your connectors are plugged in the right direction? It doesn't seem like your tail motor is bad if it is spinning and it worked before. The connectors that will affect your tail motor is your rudder/receiver, rudder/gyro, gyro/receiver, and the tail motor going to the esc. Make sure the yellow wires are all on the same side on the receiver. BTW, do you have anything plugged into gear right now? |
From my experience with the MSR, CPP2, micro Mustang, that the small motors don't seem to last long.
ORIGINAL: c9403 Solman, When Ifirst started this venture, I was looking to find that fine line where the tail wag was almost gone, but I still had good heading lock / control. If you watch the video on youtube, that guy says that you set the Channel 5 knob in the center at the 12 o'clock position. If you turn to the left, you go into HH mode and it gets progressively stronger, if you go to the right, you get RATEmode, same thing. (or vice versa) Iwas just tired of trying to lightly adjust the pot on the gyro and thought that using the transmitter made more sense. Now,Ihave a mess. Iam truly hoping that it is simply my tail motor that is out.I have heard others say that their motors wore out that quick, so hopefully when my new tail motor gets here Saturday or Monday, she will be back in the air. Chris ORIGINAL: Solman If there is no percentage on it, how would you know where you are at on the gain and why would you? On my remote, I know exactly what percentage I am at. <br type="_moz" /> |
I would think that if the tail was spinning that it should be ok. Is the trim on the TX moved off center? Did you mess with the proportional mixer on the bottom of the heli (ESC)? Either of those will make it spin out of control.
ORIGINAL: Solman From my experience with the MSR, CPP2, micro Mustang, that the small motors don't seem to last long. |
Well then, you've been lucky. I've had to replace the main motor and tail motor on the MSR once. My tail motor on my CPP2 failed on me in flight once. I believe my Mustang's motor is starting to give way now.
Well, my new tail motor and a tail boom arrived in the mail Saturday. It is now Sunday evening around 5pm. After dinner, I am going to mount up the new tail motor and boom and see what happens. Iam going to check my feathering shaft and main shaft also while I am under the hood!!
Hope to post an update later saying it was simply the tail motor. Once Iget her working again, I am simply going to control the Gyro gain via the pot. Now that Iknow you don't have to power down, it should be easier to find the gyro setting I am looking for for steady, non twitchy flight. I am already thinking ahead, if it is just the tail motor, the stock motor did not last long. Imay be looking for alternatives to that motor or just get really good at changing them out. Chris |
TADA!
Fixed. Got my tool kit out and soldered in a new tail motor and put on a new tail boom. After about 1/2 a battery pack, Ihad the gyro and the proportional adjusted back to where they belong. Afew trim adjustments and she was good to go. I was hovering in my kitchen, a huge accomplishment for me to fly a larger heli in a small space. So here are my observations as Iexamined my old tail motor. When the heli was brand new, the tail motor would make that buzzing / grinding noise that everyone complains about. Once it quit holding the nose, it no longer made that sound. The new motor is very quiet and has a manufacture date about one month after the original one put in by the factory. When the heli was new, the tail rotor would begin spinning up as soon as the main blades began to spin or shortly after. As it went out, it would not start up until much later and was weak in power. The heat sink is easy to reuse for the tail motor. It is not glued on and simply pops off and goes on the new tail motor. So, here are my theories for why the motor went out after about 20 flights: 1. Bad motor, stuff happens. 2. Crash damage???Maybe the tail struck something and caused a slight bend in the motor shaft that wore out the motor. 3. While trying to plug in the infamous yellow wire, Iplugged it into the wrong port and/or wrong polarity and fried the motor. So, I hope someone else can learn from my mistake.I believe that you can adjust the gyro gain remotely with the stock transmitter, but for me, the pot on the gyro will do fine. Still searching for that perfect setting where the twitch almost disappears, but you have good control.Not sure it exists with a non-belt driven tail, but I will try to get closer. For anyone else who wants to try, I would suggest that someone put it in plain english as to how to do it. In other words, take the yellow wire, plug it into the 5th pin from the left and make sure the yellow wire is on the bottom. Then, in using the Channel 5 knob, you get xxxxx. Chris |
Chris looking at the Blade SR from the back, towhich male plug does the yellow female plug attach? There is one empty at the left side and one empty at the second from right. Which is it? Also, I had the same issue with my tail motor coming on full blast, but discovered it was because the SR was not properly bound. Do you think the buzzing sound the tail rotor makes is a defect since your new one doesn't make that noise?
