Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
GP giant stick electrafied
Reply
Old 04-03-2011, 06:15 PM
go vertical
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GP giant stick electrafied
I started this project green to electric powered planes, my aim is to have a 2meeter pattern powered by electric. so i thought i would get a simple air frame to learn power systems on, make my mistakes on a less expensive airframe. [and sticks can be fun] I have had the ultra stick light from horizon in the past wich is no longer sold. that is why i went with the one from GP it is well built but weighs more ok now for my set up a turnigy 63 64 /230kv motor 18x8apc ele prop i am useing a electrifly silver series 80a high voltage esc .ok now my first error i am only running 8 cell the motor only turns 6000 rpm no heat in eather the motor or esc going to 10 cells as soon as they come the plane weighs 12lb and flys enemic on 8 cells am i on the right track
ID:	1588485   Click image for larger version
ID:	1588486   Click image for larger version
ID:	1588487   Click image for larger version
ID:	1588488   Click image for larger version
go vertical is offline
Old 04-04-2011, 12:41 AM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP giant stick electrafied
A 6364 motor of 230KV would be nice with a 10S set up but you try 8S with a bigger prop, try something in the 20" range and see how it works out. Let her pull more amps. Maybe a 20x10?
tIANci is offline
Old 04-04-2011, 06:00 AM
go vertical
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i will try a 20x 6-10 zinger it's what i have here i have a scale and a watt meter time to play a little
Old 04-04-2011, 11:16 AM
go vertical
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
all right i did a little playing with the 18x8 apc electric prop, it drew only 25 amps 770 watts and 9lb pull with the zinger 20x6-10 it drew 42amps 1250 watts and 12lb pull, all on the same battery the motor was warm not hot esc no heat batt fairly warm but not hot don' know about run time i didn't set my timer i am only trying 2500mah 25c i need higher batts
Old 04-04-2011, 01:24 PM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vertical ... I pull about 1KW for a 40 sized sport plane. You want to pull about 2KW at the very least. You need to up the amps still.
tIANci is offline
Reply
Display Modes
