Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
Hangar 9 Sundowner 36 ARF
Reply
Old 08-06-2011, 03:45 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hangar 9 Sundowner 36 ARF
The Hangar 9 [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN4520]Sundowner 36[/link] is a fast sport scale model that is perfect for high-speed aerobatics and club racing. Based on the Sundowner Formula 1, this speedy performer has a scaled-down aggressive racer body design that is at home equally as a sport flyer or as a serious racer. Designed to be powered by an electric (EP) or glow (GP) power system, this plane delivers racer styling at a lower cost to you.
The model is constructed of lightweight balsa and plywood with carbon fiber reinforcements for added strength and durability. The low parts count makes this ARF exceptionally easy to assemble, and with a two piece wing, easy to disassemble for transport. The one piece fiberglass cowl has hidden cowl screws, adding to its great looks. The internals are easily accessed through the removable canopy, which is held securely in place with tabs and magnets.
The Sundowner 36 can be powered for sport utilizing the E-flite Power 32 or Power 25 motors or the Evolution .40NX glow engine. The Sundowner 36 always makes it look like it's tearing through the sky. Because of its smooth flight characteristics and precise, sport handling, even intermediate pilots will feel comfortable behind the sticks. Unlike other racers that may be difficult to fly, the Sundowner 36's streamlined design makes this racer smooth, precise and ready-to-roll.
Specifications:[ul][*] Wing Span: 51.5 in (131cm)[*] Wing Area: 400 sq in (25.8 sq dm)[*] Overall Length: 44.0 in (114cm)[*]Flying Weight: 4.0 - 4.5 lb (1.8 - 2.0kg)[*]Motor Size: Power 25 Brushless Outrunner[*]Engine Size: .32 - .36 glow[*]Speed Control : 40 Amp 3S, 60 Amp 4S[*]Recommended Battery: 3S 11.1V 3200 mAh Li-Po[*]Recommended Radio: 4+ Channel Radio system[/ul]Features:[ul][*]Rock solid performance at high speeds with good low speed handling characteristics for landing[*]Two power setups: 3S/4S battery for Power 32 or 25 Option/Evolution 40NX glow engine[*]Carbon fiber reinforcements[*]Fiberglass Wheel pants and cowl[*]Lightweight construction techniques[*]Two-piece wing[*]Shown with optional aluminum spinner sold seperatly (plastic spinner included)[/ul]
ID:	1644895   Click image for larger version
ID:	1644896   Click image for larger version
ID:	1644897   Click image for larger version
ID:	1644898   Click image for larger version
Greg Covey is offline
Old 08-06-2011, 04:04 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hangar 9 Sundowner 36 ARF
The Sundowner 36 came well protected in its box. Each part was sealed in plastic so they arrived clean and separated into appropriate groups. I didn't see a single wrinkle on any of the covered surfaces.
The cowl and wheel pants were beautifully painted. The carbon wing tube and painted gear mains were additionally wrapped in paper to prevent scratches. The control surfaces were attached to there appropriate mate but the CA hinges were not glued.
A large decal sheet and 48-page manual are also provided. The manual is loaded with quality photos and step-by-step instructions for an easy assembly.
ID:	1644900   Click image for larger version
ID:	1644901   Click image for larger version
ID:	1644902   Click image for larger version
ID:	1644903   Click image for larger version
ID:	1644904   Click image for larger version
ID:	1644905   Click image for larger version
Old 08-06-2011, 11:06 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A closer look at the fuselage reveals the quality construction of the Sundowner 36 and the Easy-Access Hatch. The large hatch is held in place with G-10 tabs and carbon fiber pins for easy access and in-flight security.
The top red portion of the fuselage, including the hatch, appear to be made from a molded plastic. All the holes are pre-drilled for the wings and a fiberglass support tube is epoxied in place for the wing bar. The motor mount is lacquered for protection from glow fuel.
ID:	1645057   Click image for larger version
ID:	1645058   Click image for larger version
ID:	1645059   Click image for larger version
ID:	1645060   Click image for larger version
ID:	1645061   Click image for larger version
Old 08-07-2011, 03:20 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Sundowner 36 will be powered in accordance to the National Miniature Pylon Racing Association ([link=http://nmpra.org/]NMPRA[/link]) Electric Formula One (EF1) Rules using an E-flite [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLM4025B]Power 25[/link] motor (1250Kv), 60-Amp Pro Switch-Mode BEC Brushless [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLA1060]ESC[/link], 4-cell 30C [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLB25004S30]2500mAh[/link] LiPo pack, and APC [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=APC08080E]8x8[/link] thin electric prop.
The NMPRA Electric Formula One (EF1) is a racing event for radio control airplanes powered by electric motors. The event is intended to be easy to get into, available everywhere, reasonably priced and using off-the-shelf components to create the maximum amount of fun. While there is a great diversity in equipment available for electric models, these rules are designed to eliminate a technological advantage available to a limited few, and allow all participants to compete on an even level.
I'll also be using the new [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMAR7010]AR7010[/link] 7-Channel DSMX Receiver (in DSM2 mode), JR Sport [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=JSP20040]MN48[/link] Mini Servos for rudder and elevator, JR [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRPS388]DS388[/link] Digital Micro MG Servos for ailerons, and the optional E-flite ([link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLSP200]EFLSP200[/link]) 2" Aluminum Spinner.
ID:	1645341   Click image for larger version
ID:	1645342   Click image for larger version
ID:	1645343   Click image for larger version
ID:	1645344   Click image for larger version
Old 08-07-2011, 04:22 AM
RACJ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which KV power 25 will you be using? RACJ
RACJ is offline
Old 08-07-2011, 04:57 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
The 1250Kv Power 25 motor. I added more links above.
Thanks...
Old 08-08-2011, 01:24 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The first step of the installation is the horizontal stabilizer. After first inserting the elevator into the tail, the horizontal stab is glued in place while the elevator hangs in position. The wings are temporarily installed to insure the stab is aligned properly. The wings fit very well against the fuselage. The alignment pins are pre-installed so the wings simply press into place.
Although the manual has instructions on cutting away the covering, it is already done on the ARF model.
ID:	1646083   Click image for larger version
Old 08-09-2011, 01:39 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The vertical stab is glued in place next and the top tail wheel wire section is glued to the rudder. I had no alignment issues and the instructions in the manual were easy to follow. The rudder hinges were secured with thin CA and the tail wheel bracket screwed to the fuselage bottom.
ID:	1646675   Click image for larger version
ID:	1646676   Click image for larger version
Old 08-10-2011, 01:29 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the Rudder and Elevator Linkage Installation (page 15), it shows the elevator servo on the same side of the fuselage (left side) as the linkage exit and control horn. Since the control rod tubes cross inside the fuselage, the elevator servo must be on the right side of the fuselage. My guess is that the original prototype did not have the tubes crossed when the manual was written. The JR Sport [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=JSP20040]MN48[/link] Mini Servos are used for rudder and elevator control.
The manual does a good job of displaying the servo arm length desired so you obtain the proper throw. All the hardware worked well and the control rods were pre-bent and cut to the proper length. I added my own fuel tube keepers on each clevis because the supplied keepers were dry and brittle.
ID:	1647142   Click image for larger version
ID:	1647143   Click image for larger version
Old 08-13-2011, 04:47 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The main landing gear simply bolted in place. The metal gear section does have a front and back so you need to place the angle forward as shown in a photo in the manual.
The wheel pants self align and the only issue I had was to remove a sticky substance from the axles with Goo-Gone.
ID:	1648273   Click image for larger version
Old 08-14-2011, 07:48 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron servos were mounted to the covers per the manual instructions. A 6" extension lead is needed on the servo wire. There are no strings inside the wings so you need to feed the wire through manually. It was a fairly short run and I didn't have much trouble.
The pre-bent linkage rods and hardware are all supplied so it was a quick job to install them on both wing halves. The manual describes the servo arm length and which hole to use on the clevis for proper throw range.
ID:	1648672   Click image for larger version
Old 08-17-2011, 01:38 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Sundowner 36 comes with three different templates, two for glow power and one for the electric options. The Power 25 motor uses the inner holes and the 30mm standoffs. Note that the standoff lengths are incorrect in the manual. The center hole in the template must also be drilled out on the firewall to allow the motor shaft collar to pass through.
If you drill a few holes in the motor box for a cable wrap to feed through, it makes the wires neat so they don't interfere with the motor. If you are using the recommended E-flite motors and ESC, matching the motor wire color to the ESC results in the correct rotation direction. (counter-clockwise when viewed from the front of the model)
I needed to open the floor slot a bit with a razor knife to allow the EC3 connector to pass through. No soldering required!
ID:	1649992   Click image for larger version
ID:	1649993   Click image for larger version
ID:	1649994   Click image for larger version
ID:	1649995   Click image for larger version
Old 08-19-2011, 03:43 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The receiver and battery positions were placed per the manual suggestions. With the battery pack all the way forward, as shown, the CG was about 2-4/8" back from the leading edge. The CG range is 2-3/8" to 2-6/8" so a slightly forward CG is a good place to start. The pack can be moved aft after each flight test, if needed.
Old 08-21-2011, 03:54 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The last steps of the assembly are to mount the cowl and spinner. I used the E-flite ([link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLSP200]EFLSP200[/link]) 2" Aluminum Spinner which comes with both 4mm and 5mm collet adapters.
The cowl fits like a custom glove and is secured using two 3mm socket head screws which are hidden. After installing the canopy, you can see the Sundowner 36 is designed for a very clean look!
On my initial assembly and test flight, I only had an APC 8x6 prop available so I ordered a few 8x8 props.
ID:	1651312   Click image for larger version
ID:	1651313   Click image for larger version
Old 08-26-2011, 07:44 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Sundowner 36 was Ready-To-Fly at 56oz (3.5lbs) including the 9.6oz 4-cell 2500mAh Lipo pack. I measured 650 watts at 47 amps for a powerful 186 watts per pound after installing the APC 8x8 e-prop.
ID:	1653695   Click image for larger version
ID:	1653696   Click image for larger version
ID:	1653697   Click image for larger version
Old 09-03-2011, 05:20 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We tested the Sundowner 36 this weekend. As expected, it really has some speed! Our only issue was that it needed a bit more right thrust as it pulled left when you hit the throttle. When taking off grass, it tended to nose over on the very start but once you got some movement it was fine.
I'll post a video and more photos soon...
ID:	1656734   Click image for larger version
ID:	1656735   Click image for larger version
Old 09-04-2011, 07:46 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the videos, you can see that the Sundowner 36 is both fast and maneuverable. Although it wants to initially tip over when taking off a grass surface, once you get going, it seems to track fine. On the maiden flight, we first felt that it was wanted to pull left when accelerating hard. This was confirmed on the subsequent flights so a small washer may need to be added on both left spacers of the motor mount for a little more right thrust.
The Sundowner 36 flies as good as it looks! We did some very large loops and strong vertical runs so it has plenty of power to go with its speed. We were only testing it for sport flying and had no cooling issues. The test flights were done in some winds of 10-20mph and the Sundowner 36 handled it very well for being a smaller sized model. The design is solid so there was no warping of the fuselage or wing. Since the plane has relatively low wing loading, it can be slowed down for aerobatic sport flying. I would recommend the pilot have strong intermediate flying skills with some higher speed experience. Advanced pilots will have no problem flying the Sundowner 36 and really enjoy the way it tracks!
[link=http://www.gregcovey.com/reviews/Sundowner36a.wmv]Sundowner 36 Maiden Flight Video[/link] (8meg)
[link=http://www.gregcovey.com/reviews/Sundowner36b.wmv]Sundowner 36 Test Flights Video[/link] (15meg)
photos by "Papa Jeff" Ring
ID:	1657264   Click image for larger version
ID:	1657265   Click image for larger version
ID:	1657266   Click image for larger version
ID:	1657267   Click image for larger version
ID:	1657268   Click image for larger version
ID:	1657269   Click image for larger version
Old 09-05-2011, 06:59 AM
lumpy649
My Feedback: (75)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Greg,
Another great review by you and photos by Papa Jeff. I just picked this plane up last week from my LHS already assembled by a customer and never flown. I have a few questions about his assembly though.
1- He built the plane with a E Flite power 46, which doesn't make sense to me when you look at the kv ratings at the suggested use of a Power 25 or 32. Plus the additional weight of the heavier motor and the need to run a 5s lipo.
I have a power 25 high kvand a 32 on hand, is there any advantage of running a bigger motor? I don't think it will give any speed advantage with the extra weight.
2- What was your approximate run time with the set up you used? How much reserve did you have with the e flite battery you used?
Gary aka lumpy 649
lumpy649 is offline
Old 09-06-2011, 03:48 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gary,
Thanks for checking out my build thread. I agree that the choice of using a Power 46 motor seems odd. Perhaps it was all they had on hand. Although it is not optimal, it will fly the plane.
Your Power 32 motor will work just fine. You can see the result of the Power 25 motor in the videos. There is very little drag on the Sundowner 36 so it wants to fly fast. If you can keep it lighter, it will be easier to slow up for landings.
The pilot in the video was Lynn Bowerman from the Canandaigua Sky Chiefs. We were getting 6 minute flights with the stock 4s 2500mAh pack and had a good 15% left in the battery. The NMPRA EF1 setup is pretty light for the Sundowner 36 so don't worry about adding more weight. Depending upon how you want to fly the plane, it seems like there are many ways to alter the power system to suit your needs.
Good luck!
Old 09-09-2011, 05:32 PM
lumpy649
My Feedback: (75)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I maidened the Sundowner this evening. As per Gregs review suggestion I added one washer behind the left side mounts to correct an engine thrust problem and the plane tracked true upon acceleration. As I expected, the Power 46 motor with a 5s battery wasn't as fast as this plane should go. Too much weight and not enough kv I suspect. My Diamante is quicker with a Power32 5s setup. I'll be switching to this setup soon.
lumpy 649
lumpy649 is offline
Old 03-14-2013, 02:14 PM
dasquirrelisme
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will Hitec 82mg be alright for the aileron servos?
dasquirrelisme is offline
Contact Us Archive Advertising Cookie Policy
