Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
fly's good except the landings Bent Gear every time
Reply
Old 04-18-2013, 07:39 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default fly's good except the landings Bent Gear every time
I have a great planes EP sportster, it was the original model with a brushed geared motor , I converted it to brush less, fly's good except the landings on the grass ,I cant seem to come in and flare with out the landing gear bending , is it the approach I'm doing wrong or weak gear
suzonka is offline
Old 04-18-2013, 07:52 AM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: fly's good except the landings Bent Gear every time
You don't say what surface you are landing on but if it's grass that gear won't hold up especially if you come in with some speed. It's a sportster so you should be able to slow it down and float it in. You might also try a little larger diameter wheel .
flyinwalenda is offline
Old 04-18-2013, 08:19 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: flyinwalenda
thanks , I was contemplating on a larger wheel. I cant seem to slow this puppy down on landings, if anything I keep the prop turning and try to flare it ,it just drops out fast at about 2 feet off the ground if its to slow
suzonka is offline
Old 04-19-2013, 01:03 AM
Charley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the nose drops when it slows down near the ground then I'd suspect the CG is too far forward. Mine just floats along in ground affect until it settles in.
CR
Charley is offline
Contact Us Archive Advertising Cookie Policy
