What is a good setup for Cirrus SR22T?
TX
I am wanting to buy the Great Plane Cirrus Sr22T http://www.greatplanes.com/airplanes/gpma1363.html, the question overall is what is a good setup as I am planning to adapt the FPV system as well, but overall on motor,Esc, and battery. What would be the right path selected for me. I will be running a transmitter Futaba 6J.Any suggestion or tips will be greatly appreciated. Thank you in advance
Doesn't seem you got any replies. I presume you have moved forward on the project, but if you are still looking for a power set-up this might help.
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.rcuniverse.com/forum/m_7100376/tm.htm
This e-book will help you if you want to broaden your knowledge of electric.
Using a motor selection resource can be helpful too. The Electrifly system works well. I have had good experience with the Rimfire motors.
http://www.electrifly.com/powersyste...tem-index.html
The calculator will let you vary the prop size, flight character, weight and other parameters.
Previous Thread
Next Thread
