Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
E-Flite mini Edge 540
Old 02-16-2006, 04:59 AM
Dav0012
Default E-Flite mini Edge 540
hi, i have just purchased this aircraft and have previously had installed on another plane a hi-mark 2815 motor, but it doesnt fit the gearbox supplied, is there a gearbox that would actually fit this motor, because i wish to use the prop that is supplied to instead of a straight out 6x3 that is pretty much no wider than the cowl compared to the 12x6 with the gearbox set-up, and if there is a gearbox for the motor, will that set up work this this plane with that motor and 12x6 prop?
Old 03-19-2006, 11:24 AM
DonH21
Default RE: E-Flite mini Edge 540
http://www.e-flightline.com/index.html
They have a Cobri 28 that should fit your motor. I have the cobri 20 and it's a strong well made gear box.
