Mini Ultra Stick PNP ???
NJ
Looking for my first electric, so the Mini Ultra Stick PNP Plug-n-Play version seems like a good deal.
My question is, are the components i.e. Servos, ESC, and motor any good in the PNP? I have read many post about the Typhoon PNP having stripped servo problems, don't know if they both use the same servos. Any recommendations / advice?
RE: Mini Ultra Stick PNP ???
ORIGINAL: larrwill
ESC,
Now, if you want to go completely sick, hang a 480 on the thing. You'll need a 2100mah pack, so there goes any pretense of a light plane, but boy is it ever brutal.
I'm thinking that with a 1320mah pack and the 450 that the package will be really nicely balanced.
Here's what I wrote about mine..............
http://www.wattflyer.com/forums/showthread.php?t=5468
http://www.rcgroups.com/forums/showt...63#post5439473
NJ
Thanks for the advice. I went ahead and bought one. One batteries worth of flying and so far so good.
The elevator hinges had way to much CA and was very stiff. I worked it back and forth quite abit before installing hopefully it will be ok.
I flew it in my front yard...put it away after almost hitting the neighbors house...I'll try again later...
NJ
ESC is EFLA7310 - 22 amp with voltage cut set for 3 cell lipo it cannot be programmed for other batteries, the brake is set to off and is also not programmable.
Servo EFLR7110 - 9g
Servo EFLR7110 - 9g
I bought one on Fri. and flew it this afternoon. 3 hrs of "building", most of that was soldering the various connections. This is my first electric, and I am very pleased with it. It doesn't fly like my US 120 Lite with a Saito 180 the nose, but it was still very fun to fly.
I ran into a friend of mine Saturday afternoon at the hobby shop and he was looking at the Mini Ultra Stick PNP. I told him "Get the thing and we'll go fly it in an hour," and that's what we did. He dropped by the house and we put his receiver in it, used a couple of my batteries (he didn't own any electric stuff yet) and were out at the field in about an hour.
First, for my tastes the thing comes with waaaaaaaaaaaaaay too much aileron throw, so we moved the pushrod in at the servo one hole. It still rolled really quick, but it was manageable and my friend liked it that way.
It flies just like my Ultra Sticks except the little 450 doesn't have as much zip. It's not bad, but I like insane performance. Most guys will be delighted with it, and I'm sure it would be better with a 1320 pack instead of my 2100mah bricks. we were landing every 20 minutes to check everything, so the 450 isn't a current hog.
One thing I would change if I bought one is to reprogram the speed controller to have a faster start up. The motor doesn't snap to full power from a stop as fast as I'de like, but most guys will like it that way. I use the throttle alot so when I need power I need it now.
I don't know how to reprogram the speed controller, but I'm sure I can download the instructions from e flite's site.
Mostly my impression is this is a nice little plane that most guys will be delighted with. It does everything exactly like my Minis do because it's the identical airframe. At the cost of the plane and servos, the motor and speed controller is free, so it's a great bargain and a great way to get started in Ultra Sticks. For those who buy it, they can fly it until they want more power and then put the 480 in it. Even if you throw the 450 motor and speed controller away, it didn't cost you any extra money. But, be forewarned, the 480 is an insane power choice for this plane. most guys will like the 450 just fine, plus it's lighter and requires less battery.
NC
Bought my MUS PNP yesterday and will be putting it together later on this afternoon after work.
Can't wait to get it up in the air and experience how great this plane is!
NC
Had my maiden flight a couple of hours ago and everything went well. Excellent quality compared to other PNP's, plenty of power for all kinds of aerobatic maneuvers. Tried some hovering but did not do very well at that. I guess every plane is quite different when it comes to hovering..... may have to ad some weight to the tail.... but I will hold on for a while before I think about any mods.
Take offs and landings were excellent and only took a couple of clicks to get it trimmed properly. I did notice I had to click the elevator up slightly beyond neutral to make it fly level. It did affect inverted flight since I had to keep some down elevator to keep it flying level while inverted. Need to check the CG to see if that's what is causing the need for up elevator adjustment. Loops and rolls were very smooth at both HI and LO rates.
Overall: I'm very impressed with the MUS -- It will most likely become my best friend!! I highly recommend it.
Sorry I took so long to get back to you. I've been out flying my new Ultra Stick 25E all week and have been offline.
My friend who bought the PNP didn't have any batteries because he's a nitro guy, so we used my 2100s. The PNP was fine with the big battery, but I'm sure it would be even better with a 1320 or so. With the 2100 and 450 motor, we had more run time than we could use. We really don't know how long it would run, but I'm suspecting 20 minutes would be easy.
I fly 2100s in all of my Minis, but remember I've got that firebreathing 480 on the nose. The PNP with the 2100 seemed to fly just like my plane, only without so much power. Really, you don't need the 2100 unless you want a big gas tank or plan to upgrade to the 480 later.
ORIGINAL: Wide Open
Hey Doc, I was planning on getting a 2100 lipo for it, do you think its too heavy? would a 1500 be better?
AZ
thanks, ill just go for the electrifly 1500 balancing one then. ive already got the triton charger, so its easiest for me to get their balancer and lipos.
ORIGINAL: Wide Open
make it more affordable?[&:]
ORIGINAL: P-51B
I really have to wonder why they didn't put the 480 on the PNP instead of the 450.
$5.00 difference [:@]
NJ
Just an update to this post. I have quite a few flights on the MUS now and have had no problems with any of the electronics. The only change I have made was to remove the stock electric connectors and replace with Deans.
I also tried using a 1320 battery and it seems to balance better then the 2100 but I can't say it made much difference flying, at least with my skill level. Still had plenty of flight time on the 1320.
Only problem I had is the landing gear mount is not very strong combined with very long gear, and I managed to break it off on a landing. I repaired it once but it did not last. I belly landed it a few times but as the ESC does not have a brake, I went through a couple props. The solution was to mount a couple wood dowels through the fuse and rubber band the gear on.
I just have an economy charger but I think the 2100 is about half to 2/3's discharged after about 15 minutes. It does get sluggish at that point with the 450 motor so I just pop in the next battery.
With the 900 it has an AUW of about 17oz according to my cheap postage meter and crawls with Crow enabled. Probably my favorite of the three to fly with. With the 900 tucked in the very front of the battery compartment, it balances perfectly. I would estimate flight times with conservative flying at 12, 15 and 24 minutes respectively.
AR
Ok so my next ? is i have 2 brand new Ap .09 Hornets, and i'd love to bash this creature up and see how it performs on nitro. Any advicewould be appreciated as i just ordered the basic arf.
ORIGINAL: larrwill
doesnt using the brake shorten the life of your motor though?
NJ
Humm...The instructions that come with the PNP ESC specifically state that the brake cannot be programmed, and it's not the same ESC as EFlight sells separately. I tried fiddling with the programming but was only able to reverse the direction of rotation. If anyone knows of a secret way of programming the PNP ESC I would be curious to know, although as I am no longer belly landing it is not critical.
NC
Doc,
Where do you get the nylon bolts? Are they readily available at LHS's?
I hard landed my MUS once and did a little damage to the fuselage, not bad, but I sure want to avoid any greater damage.
I can land it nicely, but that day was rather windy and landed a little too hard.
