Plane for 100 x 200 field?
NJ
Looking for suggestions on an aerobatic plane for a small field 100' x 200'. I am new to electrics and bought a Mini Ultra Stick thinking this would do. While it is possible, the MUS is too fast and fragile to actually be fun in this small space.
Also, something really durable would be nice to fly low etc. without worry. I don't mind a profile, but prefer something with an airfoil wing over the flat style planes.
TX
RE: Plane for 100 x 200 field?
ORIGINAL: larrwill
Cheers,
CR
CA
Hi it is not the size of the field but what is on the boundaries. Any model is capable of taking off from that size but keeping it over that patch of ground would be a miracle unless you were an accomplihsed 3-D flyer or had a very light weight and slow and I mean slow airplane. Norm
suggest helicopters
suggest helicopters
TX
ORIGINAL: normgoyer
suggest helicopters
suggest helicopters
CR
ORIGINAL: normgoyer
Hi Charlie, you are probably right but what is a TM? Norm
I have a Clancy Lazy Bee, electric 3 channel. Seldom leave the immediate vicinity of the runway, I'm sure I could fly it within a 100' x 200' space. Same for my X250. They both handle mild wind pretty well.
Good luck,
Dave Olson
CA
Hi, TM great plane have had many of them and in fact taught all my kids to fly with one. There are 10 of them flying each week at our club field. My field is 15 miles long and 3 miles long and I still manage to run into my Suburban every now and then. Norm
over the 15 years I have had the big old beast there are three dents from prop spinners one by me and two by my kids
TX
ORIGINAL: normgoyer
I'm sure a competent pilot could fly the small version in a 100' by 200' box easily.
CR
NJ
The 100x200 is currently clear of trees and is my front yard. There is a group of very tall trees accross the street about 40' from the front 200' side of the space, and houses around, I could probably call it 140x230. The boundries of the space are not all solid (i.e. trees and houses) but I perfer to not fly over neighbors yards and houses.
Not an expert, intermediate skill level. I had a tough time keeping the MUS in that space and strayed out most of the time.
I would like it to be as aerobatic as possible.
What is an X250?
What is an X250?
TX
ORIGINAL: larrwill
What is an X250?
What is an X250?
Not surprised you have trouble keeping the MUS in the available air space. One of my friends has one. I've flown it. It's not as fast as my Super Sportster EP but it's quick enough at full power. Both of them will glide a long way in ground effect unless you drag them in at a high AoA, or slip them in. Have you tried the flaps on the MUS?
I did a Google search on "x250 model airplane." Came up with a X250 low wing model from SR Batteries. That might be it. About the same size as the MUS and slicker.
Cheers,
CR
CA
For years I lived in West Mass and lost just too many early RC models in the trees and corn fields. My brother who lives in Syracuse, NY has no place to fly his electric airplane so had to switch to helicopters. I got tired of digging my full scale aircraft out of the snow and ice and bailed for California and the High Desert 33 years ago. Now I can fly every day of the year, real or scale size. It was the single smartest decision I have ever made. Your feet are not welded to your hometown, they can be moved. Norm
TX
ORIGINAL: larrwill
Check out the Mountain Models Magpie Sport. You should be able to keep it in that space. It's a 4 channel set up.
It's foam with an airfoil wing. Flies slow.
Here's a link to the page on that plane. Click on the "Images" tab for videos of it in flight.
http://www.mountainmodels.com/produc...dbe49a7ff5cc3b
Hope this helps,
BobbyG
TX
ORIGINAL: normgoyer
I'm not complaining, just stating the facts of my residential area. I'm not moving anywhere . This is my retirement home; I just turned 68. I'm 6 miles from my club field and can get there in 15 minutes. That'where I do most of my flying - 1/4 scale to park flyiers.
Anyway Norm, you sure know how to add off-topic comments to a thread.
Cheers,
CR
TX
ORIGINAL: BobbyGee
Hope this helps,
BobbyG
Hope this helps,
BobbyG
Hi Bobby,
If I was looking for a small-field aerobat, that Panic 3D would be my choice instead of the Magpie.
Cheers,
CR
TX
ORIGINAL: Charley
Hi Bobby,
Cheers,
CR
Hi Bobby,
Cheers,
CR
Yup. The Panic was my first thought, then it seemed to me that larwill might be looking for something a little tamer and more of a "lazy" front yard flyer that can do some aerobatics without being necessarily a growler.
The Magpie came to mind because of that - sort of a Sunday flyer kind of plane.
Panic is a good possibility, too. No denying that.
Both are airfoil wing foamies that can take a ding and not have to go in for repairs every time.
BobbyG
ORIGINAL: larrwill
http://wattflyer.com/forums/archive/...hp/t-3562.html
However, it is a fast plane and it covers ground so fast that even a soccer field is a little marginal. I've got four of them and think it's the perfect plane, but not for a field as small as you're talking about. Maybe if you added crow.
Lots of guys like the slo stick, but I've never seen one fly. I don't think they are very fast, so it would be ideal for a small field.
NJ
Thanks to all for the suggestions.
The Mountain Models foam planes look interesting, both the Magpie Sport and Panic. I would lean toward the Panic but then maybe the Magpie Sport would be easier. Maybe I'll look at some of the small foam 3D planes also. Still open to suggestions. If I have success with this I'll post the results.
I have a computer radio so when I get a bit better with the MUS I'll try the crow and flaps.
FL
If you are looking for a great flying 3D type, then take a look at North East Sail Planes "Tuff-E" It will fly in a parking lot, go NUTZ with big throws, or will fly docile with low throws. It is a blast to fly! Made from EPP foam ... takes a lickin and keeps on tickin!
Bruce
Bruce
I am flying a MUS now and it would be tough with only that much room. I built a Mountain Models Tantrum 3D and flew it from the infield of my son's T-Ball field after games. It was tight with trees and tall pole lights all around but you can harrier so slow and turn so tight it made it possible.
NC
ORIGINAL: larrwill
good flying
ds3
TX
hey i fly in a feild about that size with goal posts in the way and i fly a pylon racer alon with other planes. the preoblem isnt the feild really what you need to consider is your skill level if you are beginner i suggest a firebird slow but not to slow. You will be fine all you need to do is take off the climb out to about 100 feet or so then you will be fine and have all the space you need i suggest flying and a 300 by 300 yrds perimeter but for tricks climb about another 25 or descend. what ever you are more comfortable with and preform them above the feild only
My Feedback: (10)
QC, CANADA
airfoilz yak 54, by a longshot...
meets all your criteria, has an airfoil, is extremely aerobatic yet stable and tame, slows to a crawl and harriers without any wing rock; you can literally walk behind it as you circle your patch...
I fly it in a 20 by 60 clearing... the rest of the park in front of my house is trees and power lines!
TX
I think the AirfoilZ Yak is the ticket here is my video of me in my front yard.
http://www.youtube.com/watch?v=aIXHe_WQth4
My Feedback: (10)
QC, CANADA
I should have said EXCEEDS all your criteria...
Mikey, my "park" is a fraction of the size of your front yard, and literally riddled with obstacles, my flying skills are a mere fraction of yours, it'll be a while before i feel comfortable hovering in my living room, i still try to keep it higher than ceiling hight when i do hover outside... But my point is if a novice pilot like me can have fun with it in such a small area i think most anyone should be able to handle it in a 100x200 foot area. Of course the usual precautions and common sense apply...
The yak seems to be the ideal version for this purpose, that was probably what made me lean towards it over the others but i am sure the mobius and the edge would still be better than pretty much anything else on the market. If you want "large scale" stick time anywhere anytime these things are the ticket.
I am by no means affiliated with airfoilz or 3dx hobbies and unfortunately, i will pay for my next airfoilz just like everyone else.
I just watched the mobius video, not every day do you see a pattern plane hover like that, most all of them have ailerons that stop short of prop wash, this really hurts their roll control at low speed, and allows no roll control at all in a hover. These guys pulled it off, look at those multi point rolls, I'd be hard pressed to do that with a gws formosa 1 on low rates. And give it the rates you want it ain't 3d'ing like this bird.
Even someone looking for an aerobat rather than a 3d plane can enjoy these because they really fly too, and contrary to your average aerobat if your rates are high enough you can literally yank it out of the nastyest situations without risking a stick fight to the ground.
oh and larrwill, whatever gear you have in your mini ultra stick should do just fine on these 3 planes. for the purpose of aerobatic flying. a lighter pack than a 2100 would be preferable though i'd fly one in a 100x200 with confidence, in even greater winds than it can allready handle.
