E-Flite Mini Pulse XT Owner's Club
Dr Z,
Thanks, now it's clear. I wasn't aware that also the tail wheel can cause trouble, so I'll keep that in mind, too. Wish you good luck for rebuilding your plane!
regards
Winni
Hole in the fire wall, epoxy, balsa, duct tape, bailing wire and a prayer and she'll be ready to crash again!
I'm pleased to announce the successful resurrection and (2nd) Maiden Flight of my smashed Mini Pulse. (Pics of the carnage and rebuild in progress are in my previous posts page 77 and 78). The rebuild took lots longer than I expected, but was most gratifying. I never worked with light ply or covering material before, and discovered I really like the Ultracote covering process. It's very Zen.
I was able to shove the dents and fractures out of the battery cover from below and CA it all into relatively good shape. I left the original covering and battle scars on, just to give her a little character. I'll probably straighten, spackle and recover that piece after a few more flights, or maybe not.
Added weight is negligible and she balances with battery nearly in the identical position as pre crash. She came out straight as an arrow and solid as a rock, and flies perfectly. No trim adjustments needed at all from before the crash. Yay!
1. im not sure on what motor to buy, have seen posts for the 450 and the 480, am leaning towards the 450 as its just the easier option for me as for the instalation i mean, just bolts strait in, were as iv read the 480 has a diff foot print so new holes would have to be made in the firewall. what ever u rekon, where sould i get it from and what should i avoid, i live in the uk so not really sure were to look?
2. what servos do u rekomend, im no stranger to the whole rc and servo thing as iv raced nationaly in rally cross, so is there any need for digital servos or would coreless be fine.
3. lastly is there any major tips anyone could give me before putting it all together, as the last thing i want to do is put it all together and find out there is something the instructions doesnt tell me,
thanks,
steve
thanks,
steve
http://www.youtube.com/watch?v=z6L0T0-lwLk
http://www.youtube.com/watch?v=I-kZzzRMFEY
RZielin, I did the same damage to my mini pulse when I swatted away a fly on my arm while doing a low pass. It also flys great after glueing the puzzle back together as the first video shows. In the video I am pointing out the damage before I launch it.
Welcome to the "club". It's worth searching this thread, altho it admittedly will take a long time to read it all. Starting with nylon bolts for landing gear and/or reinforcing the landing gear mounting area seem to be the biggest tips. Several methods of reinforcement (including my own in recent posts) are shown in this thread. Since graduating to steel landing gear bolts, I've had many "spirited" landings including stall drops from a few feet upwith mild LG bends but no fuse damage whatsoever. (My modeling skills far surpass my flying skills ).
I don't understand the enthusiasm for the 480 motor, as the 450 flies this plane very well, with low weight, good balance and easy install. But then again, I'm not a good pilot. Still, seems to me you want a more advanced aerobatic plane if you need that "480" performance. Just my 2 cents (?pence?).
I agree the e-flight 450 is probably better than the knockoff PNP 450 that I use, but even my PNP 450 is adequate for medium speed aerobatics. (My friend's Mini Ultra Stick with the "real" 450 seems to blow my 450 out of the water).
I cannot speak from experience, but knowledgeable posters on another forum seem to agree that the E-Flight motors are only average quality but but premium priced. Hyperion, for example seems to show much better efficiency, weight, and power, better build quality and similar or even lower prices. Find one with similar max amp/wattage and KV (around KV 900) and you should be good. You can use WebOCalc to confirm your choice will fly the plane well. You'll pay for the better motor quality by having to fit it to the plane though.
http://flbeagle.rchomepage.com/softw..._imperial.html
Hope this helps.
Also, speaking of other brands of motor, I would actually put the E-Flight motors above middle road. I have at least a dozen of the from Park 400's to Power 60's. I also have some Hackers, Axi's, Exceeds, and Rimfires. To be honest, I can't tell the difference between brands of similar size and ratings. I normally get 30-40 flights each week and fly all winter, in the snow, so as far as how well they last, I've only smoked two motors in 4 years and that was because I deliberately over propped them to pull more power than the motor was rated for. The only motor that has ever really given me problems was a Scorpion, and that was because I actually believed their spec sheet, rather than trusting my experience and judgement.
I have had about 20 flights of my MPXT and it is a great plane. I have done some of the mods to it before its first flight. So I do owe some thanks to the following: PZielin for his structural modification and tail wheel fix and Winnitwo for his battery mount.
<o></o>
I haven’t changed the mounting bolts to nylon because the field I fly from is grass but it is pretty smooth, the 495<sup>th</sup> R/C Squadron keeps it cut short. Plus I must be getting a little bit better at this R/C thing because I haven’t had a bad landing yet….OK the real reason I have had good landings is really because of the MPXT not the person at the controls.
<o></o>
My only trouble with the MPXT is the ground handling. I have done a few ‘donuts’ on the field trying to take off. Today I read Newjak’s post about checking the wheel alignment. Mine was off just a tiny bit so I bent it so that it (looks anyway) in line with the rudder. I also did a mod of my own to the tail wheel wire. I added a small bit of epoxy putty to the tail wheel wire to keep the tail wheel centered with the rudder. Haven’t flown it with the epoxy putty and the adjustment yet but I hope it will now track straight on the ground.
<o></o>
I also added some thin plastic between the wing mounting bolts and the tail mounting nuts. The original tail nuts I replaced with self locking nuts. With the thin plastic it will keep the wood underneath from compressing so the plastic will spread out the load
<o></o>
My set up is:
<o></o>
E-flite 480 1020kv motor
APC 11 X 7E prop
E-flite 40 Amp
E-flite 1.75 Aluminum spinner
Hitec HS 65 HB servos (fit with just a little bit of trimming)
Hyperion VX G3 35C 2200 lipo
<o></o>
Thanks All,
<o></o>
Steve
Steve
Has anyone else has this problem with the 450 motor in this model?
TP
Been flying my pnp Mini Pulse for about a month. A very nice little airplane. Power is stock and, I feel, an excellent match for the airplane. The 10x8 electric prop recommended by the manufacturer as an ''upgrade'' doesn't seem like much of one if any, so I'm using an APC 10x7 slow flyer which works very well.
TP
appears to draw less current and allow longer flights at the same performance. It should have faster top speed but it seems only slightly so if at all. I'm sure low speed emergency acceleration/thrust is not as good with the 10-8 E prop, but this plane doesn't need it-it's nearly impossible to stall anyway. Slow Fly props are power hogs. I recommend anyone trying a 10-8 E prop (not SF) as soon as they're comfortable landing the plane and avoiding accidents. Better for your batteries.
Furthermore, the E-flite SF props sold separately require lots of reaming or drilling. They are not drilled the same as the ones that come with the plane. It's a real problem to keep the hole straight and centered. Not recommended once you break your stock PNP E-flite prop. Stick with APC or Master Airscrew.
TP
Here too I found that the aileron throws out of the box were equal in up/down. Aerodynamically , this is wrong. It was easy to slip the control horn forward a notch so that there is slightly more up than down.
I'm not certain, but having the servo's (weight) back in the tail feathers just bothers me intellectually. One flight is not nearly enough to make any serious judgements, and I'm looking forward to putting some more stick time on the airframe. I would be interested in hearing from other flyers as to their set-ups. How much throw and what hole is the best for all around aerobatics?
KKKKFL
I did move the servo horns one click forward, now have more Up than down for the roll axis, hoping to try this W/E. As for the balance being correct, sure that's correct, but having weight at distant ends is a no-no since the moments need to be overcome. Its like the long pole that a tight rope walker uses to balance. With weight at the extremes, ie the nose and tail, you have balance, but making the tail flip is a little more difficult since the plane needs extra energy to start the momentum..
I hope I'm explaining this well enough. At any rate the Mini is very light, and thus these minute details go to add up. In a perfect world the battery and the servo's would all be centered at the middle and you would still retain the balance.
Now on a separate note, it seems some are worried about the landing gear ripping out. Do I really need to replace the 4-40 steel bolts with Nylons?
Also any flying tips?
I have also seen others complaining about the L/G, but I have had no problems. I do fly off a paved runway however
First shot rough cutting the aluminum with Dremel Wheel
Next shot is the plate prior to installation Note the large fender washers that are used to distribute loads
Finally, installed, a wood screw is used in the front, and you can see the original bolts are also still used, the combination should provide a 3 position bolt on of the LG vice the original 2.
Thanks for the initial info... Now I just need the wind to die down so I can test in the real world.
KKKKFL
Franco, I have to tip my hat to you for coming up with what I think will be the ultimate solution to the weak gear problem. After nearly 2000 posts with at least 50 landing gear modifications, I think someone (that would be YOU, Franco) has solved the problem once and for all.
I hereby retract my post above. Well done, Franco!
Next step is to dig into the flight characteristics. I will be looking for the best CG location for Spins first. My next favorite after the spins upright and inverted is the Lomecevek but that will be a good many hours of flight time away. Of course to get proficient one needs to fly lots and lots on the same model, so I wanted to get that weakness eliminated. I would like to know what folks thing is the best amount of throws for the surfaces. I will measure what I currently have and post later today.
KKKKFL
It's someplace to start from
CG is 2 1/4 inches back from LE
Up on Aileron is 3/8 inch or for the metric crowd 9mm
Down is 1/4 inch or close to 6mm
Elevator is at 5/8's up (20mm) and down is 7/8's or 25mm
Rudder is side to side almost touching the elevator when elevator is centered.
I measured the elevator by placing a business card parallel to the bottom orange stripe.
Total weight is at 1 pound 12 & 3/4 Ounces.
Wind today is at 20+mph ARghhhh.
KKKKFL
The little MPXT has a tendency to float (endlessly) on final. It'll be interesting to see how you handle that little quirk and where you finalize the C/G.
