Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
Nitromodels PREDATOR RQ-1B
Reply
Old 04-06-2009, 03:12 PM
  #726
reSpawn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nitromodels PREDATOR RQ-1B
Is there any flight simulator which includes this plane?
reSpawn is offline
Old 04-06-2009, 03:35 PM
  #727
jumper666
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RealFlight has some Predators for download. They do not act too closely to the Nirto acft but are somewhat helpful.
jumper666 is offline
Old 04-18-2009, 10:54 AM
  #728
RaWe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys!
I found the link to this thread from Chris Anderson's awesome DIYdrones.com website. PapaJeff has done a terrific review and hosting job here too! [sm=thumbs_up.gif]
Been reading a bit about the nose steering issues posts here and would like to share a solution for mine (not NitroPlanes Predator).
I use an external V-tail mixer, a 'Y' connector instead of using V-tail mixer on TX. My setup allows separate elevator/nose steering and elevator inputs as per normal at minimum weight/space cost.
The wheel steering servo is connected as follows:
From V-tail mixer connect one lead to elevator channel on receiver. The 'Y' connector goes into the rudder channel. The remaining lead from V-tail mixer and nose wheel steering servo is connected to 'Y' connector. Connect the 2 servos controlling V-tail to the V-tail mixer output terminals and you're all set![sm=biggrin.gif]
[youtube]http://www.youtube.com/watch?v=Ih4z0awyFL0[/youtube]
RaWe is offline
Old 04-18-2009, 12:07 PM
  #729
lejongleur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good solution to the nose-wheel problem! But......make sure you put the wings on before takeoff.
Who makes the predator shown in your video?
lejongleur is offline
Old 04-18-2009, 12:36 PM
  #730
RaWe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TMPro
RaWe is offline
Old 04-18-2009, 08:19 PM
  #731
CaptainRandy
CaptainRandy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My nose wheel steering works great too. I just have it tied to the aileron channel with a Y harness. Only takes a tad of steering to keep her straight, and taxing around at low speed is no problem using the right stick/ailerons either.
The shock absorber/servo saver works great also.
Oh and it flys well too. That's a plus
ID:	1182893   Click image for larger version
CaptainRandy is offline
Old 04-18-2009, 09:42 PM
  #732
RaWe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very interesting that shock absorber. I've had 1 stripped nose servo from a rough landing so far...
Here's another version using spring wire. Simple but should work...
RaWe is offline
Old 04-28-2009, 05:25 AM
  #733
CaptainRandy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think that would save servo gears, but good for adjustment.
Old 05-16-2009, 09:12 PM
  #734
opus444
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So does anybody know of putting a park 400 inrunner on a gearbox on the back of this plane?? What do you think??
Thanks for any help.
opus444 is offline
Old 05-17-2009, 08:52 AM
  #735
papajeff
papajeff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Opus,
The Predator does not have much room within the cowl for a gearbox type of set up. It's really designed for a
250 - 350watt outrunner motor which is a perfect fit with some short standoffs. These motors are readily
available, reasonably priced and power the Predator just fine for "scale" type flying.
ID:	1200191   Click image for larger version
ID:	1200192   Click image for larger version
papajeff is offline
Old 05-17-2009, 07:27 PM
  #736
RaWe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Papajeff,
When I set up the ESC and battery in my (not Nitroplane) Predator like in your photo, with long battery leads thru the fuse and the receiver up front, I had huge interference problems. The plane was unflyable. Did you not not have any interference or signal loss problems?
RaWe is offline
Old 05-17-2009, 08:53 PM
  #737
papajeff
papajeff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RaWe,
I had no problems with my Predator, eventhough I extended the battery leads about 18". For the first few
flights, I was using a Berg 7P receiver with my JR 9303 transmitter. Then I switched all my planes over to
the 2.4 system. I believe that the 2.4 Spektrum system using a 6100 receiver, is the reason that I have had
dozens of flights and never encountered a problem with control or range.
ID:	1200721   Click image for larger version
ID:	1200722   Click image for larger version
ID:	1200723   Click image for larger version
papajeff is offline
Old 05-17-2009, 09:23 PM
  #738
RaWe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An u didn't even have to braid or twist the battery leads... Did the Kit manual specify this ESC battery set up? Just as well I don't have a 2.4gHz radio to try with so had to resolve d problem by other methods so it's flyin now. N'ways nice blog u have here!
RaWe is offline
Old 05-18-2009, 07:43 AM
  #739
papajeff
papajeff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RaWe,
I'm pleased to hear that you have resolved the issue and that your Predator is now flying. Remember, with those
long wings (63") and the short fuselage, the Predator should be flown in a "scale" manner and leave the acrobatics
for one of your other planes. How about a photo or two of your Predator?
papajeff is offline
Old 06-02-2009, 04:29 PM
  #740
IndiQa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff,
I see in one of the pictures on the Nitro Models site that the Predator has a camera dome on it. Directly under the pod.
Is this your plane?
If so where did you get the dome?
Or do you know where to get one?
Curt
IndiQa is offline
Old 06-02-2009, 08:46 PM
  #741
papajeff
papajeff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Curt,
Yes, it's my Predator and the dome is just a piece from one of my Grandson's toys. It was my attempt to make
my Predator more scale-like. I did just order one of those new mini video cameras from Nitro;
http://www.nitroplanes.com/mifpvcocaupt.htmland will start to do some flying videos just for fun. I'll
post the results.
Quote:
ORIGINAL: IndiQa
Jeff,
Is this your plane?
Curt
papajeff is offline
Old 06-19-2009, 04:39 PM
  #742
videomike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
    I've been reading this thread , with interest,  for the last few days. I'm just a begining flyer. mostly on simulator. I have a predator on order from hobbycity. The only one they have available is the TM Pro with 74 "  wingspain for $65 and a couple of  Turngy BL motors for  $16 and $19 . The downside is that it's a back order and the shipping is direct from Hong Kong at $27. Since the availablity of this plane is so scarce I went ahead with the order. It is promist for two weeks and one week shipping. I will let you know how I make out.
   Thank you Papa Jeff and the rest of the contributors. Excellent thread interesting plane.
                                               Mike B
videomike is offline
Old 06-19-2009, 06:22 PM
  #743
videomike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If anyone has some info on a Realflight sim I would appreciate it.
                         Mike B
Old 06-19-2009, 11:06 PM
  #744
lejongleur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I looked at the 74" Predator on Hobbycity with interest - it does look rather similar to the Nitroplane 63" one, but some of the innards shown on the site are a bit different. However, with a 6ft wingspan, it should be extra-cool! Please keep us posted on how your build and flying goes. Thanks...Chris
Old 06-21-2009, 08:01 PM
  #745
videomike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chris
It seems real exciting, but if the stats are correct it acutualy has 30 sq inches less wing area.then the nitro. Id like to load it up with a cam and transmitter up the road. Have you seen Helomix's vid . The link is at post #585, fantastic, It must be really exciting the fly like that. I could use an opinon on a motor I bought a Turnigy 2209 1050kv Wt 1.6oz Thurst 28 oz ., because I thougth it wound balance better. I'm guessing the cam gear will weight at least 6 oz. Total weight might be 38 - 45 oz. Was wondering if a sronger motor might be better? If anyone could advise me on weight to thurst ratios I'd like to be informed.
Mike B
Old 06-21-2009, 10:44 PM
  #746
lejongleur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, so your motor can do probably 180 watts and Hobbycity reviews agree with you at 28+ ounces of thrust. As I'm sure you already know, this plane is not to be flown in any way dramatically, unless you want the wings to come off, so you may have enough power and thrust to fly nicely. The motor is certainly very light. Bear in mind, if this is similar to the Nitroplanes model, your MAXIMUM prop diameter is 9", and you will need to put some kind of tail skid to avoid prop strikes on takeoff/landing.
FYI, my setup is a RC1200 outrunner from Compass House (an Ebay store), with a 3-blade counter-rotating 9x7 prop from Hobbycity. The motor weighs 1.8 ounces, and Iget 230+ watts using two 1000mah 3S batteries in parallel (up front, to fit nicely.) With this setup it seems to fly easily on less than 1/2 throttle.
Also FYI, I previously weighed some video equipment:
FlyCamOne2 with SD card and bracket - 1.6 ounces
Flip Mino - 3.3 ounces
Tony Hawk Helmet cam with SD card and batteries - 3.5 ounces
2.4GHz wireless videocamera with adapter and 9V battery - 2.8 ounces (poor performance &range)
- So you can easily add a camera of some sort. In my case I would put the camera up front (luckily prop is at the back!!!) and use just one 1300mah battery (instead of 2x1000mah), which would save me 2.5 ounces, and still give me flight times of 10 minutes (it uses 90-100 mah per minute cruising around).
Good luck with everything and please keep us posted...Chris
Old 06-22-2009, 12:47 AM
  #747
videomike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My plan for the camera is a 200 Milliwatt  transmitter (2.4 gig) with a high res miniture cam (420 lines res)from hobbywireless. probably with a 2.8 lens. Spent today hooking up a 2.4 gig reciever and an 7' LCD monitor to run on a 12V gel cell. Do you think I should try 900Meg instead. A pal gave me the transmitter as a gift.  Which setup worked best for you. I'm a little in love with being able to see from the cockpit maybe even fly from the cokpit.
    This guy Helomix flies wearing google monitors. Thanks for the advice
                              Mike B
http://www.youtube.com/watch?v=vRbB-Bz4iP0
Old 06-22-2009, 01:03 PM
  #748
lejongleur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the things (other than laziness) that has slowed me down with aerial video is the fact that 2.4GHZ systems do not work with Spektrum - apparently the plane flies OK, but the video is adversely affected by interference. I can't remember where I got my 2.4GHz system, but is was only about $50 for everything, and worked inside the house OK; any distance away was a problem. I would suggest you try 900MHz, as apparently 1.2GHz is not legal in the US (don't know why.)
Keep me posted...Chris
Old 06-25-2009, 11:08 PM
  #749
videomike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like Nitroplanes has the predator back in stock, if anyone is still reading this thread. I'm going to wait it out and see in the 74" one comes in from hobby city.
Hay chris about the camera, I'll hold off from up grading my 2.4 gig system. But I may as well experiment with it since it's paid for.
Mike B
Old 06-30-2009, 06:36 AM
  #750
JerCo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I purchased my predator from Nitro Planes a couple of weeks ago, because this sight sparked my interest. Question: has anybody assembled the plane per the manufacturers instructions without all of the upgrades? I have a small 4 channel transmitter and 6channel receiver on 72 mhz. Will the plane fly with just using the tail as elevator, no steering,and ailerons? I have a 400 and 450 speed motor, which one should I use?
Thanks for your help
JerCo
JerCo is offline
Reply
Display Modes
