If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 8 of 10 FirstFirst ... 678910 LastLast
Results 176 to 200 of 241
  1. #176
    Join Date
    Sep 2003
    san antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: E Flite Eratix 3D 25e ARF Owners Club
    ORIGINAL: wrpsr1911
    I know of about 12 Eratix's in the air and I know of NO ONE flying with flaperons or spoilerons!! Not needed. It slows so you can walk beside of it and does all the manuvers that I am capable of performing, without anything extra. ENJOY !!
    Thanks! You just saved me some extra work. I actually had the flaps and elevator coupled on my E3D and It made the tightest loops I've ever seen. It was comical.
  2. #177
    Join Date
    Sep 2008
    Carefree, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I Agree with WRPSR1911, not needed with this type of airplane.
  3. #178
    Join Date
    Mar 2010
    Pitt Meadows, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just bought a used Eratix 3D. Looks well built and probably almost never flown. Somewhere on the World Wide WebI saw specificdetails about setting up the Spektrum DX6i for the Eratix. Seems to me there was some videos as well! But now that I have the plane, I can't find them. Can anyone help me with a link???
    Join Date
    Jun 2009
    Burbank, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi I am having a problem with my motor set up I am using the Turnigy 42 50A 700 motor in my Eratix plane with a Turnigy 80 Plush ESC. The prop I am using is 14x7. Without the prop the motor works fine. When the prop is put on at 3/4 power I get a screeching sound and the motor shuts off. I am using a 4S 2200 battery. The motor is not rubbing on anything. Can anyone give me some help to make this run. Thanks
  5. #180
    Join Date
    Feb 2008
    Norwalk, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I suspect you have a bad motor with bad bearings - not uncommon with smaller Turnigy motors sorry to say. I just sent one back with a similar problem - bearings lock up under load, but the motor seems to turn fine when it cools down. Hope this helps...Chris
  6. #181
    Join Date
    Jun 2009
    Burbank, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I even programed the ESC cutoff threshold to medium and high and it still shut off. I might just get the Eflite 32 and there own 60 ESC at least they are in the US and if there is a problem they will take care of it. I know the cost will be more but I just want to fly my plane without this hassle. I have had good success with very small Turnigy motors with my foam planes but not this time. Thanks for responding lejongleur.
  7. #182
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's the way to go Eflite Power 32.
    I've been flying my Eratix with this motor along with 60 amp ESC using Turnigy 4S 3000 mah 20C packs for some time. It all works great.
    Not raining? Not too windy? Guess what I\'\'m doing!
  8. #183
    Join Date
    Feb 2008
    Norwalk, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used a Scorpion 3020-12 in mine. Very comparable power to the Eflite Power 32, lighter weight, a little less expensive. Both are good choices. Sorry you had bad luck with your Turnigy - they are usually pretty good, and great value.
  9. #184
    newjak's Avatar
    Join Date
    Nov 2006
    Cheswold, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bart4u
    It sounds like an ESC timing issue to me. I had the same problem with my eEratix. Just change your ESC timing and give it another try. I am running the Eflite 60A pro ESC with a Power 32 motor and 13*6.5 prop. I bought my ESC second hand, but as soon as I changed the timing all problems went away and I've been flying it carefree ever since.
    AMA Park Pilot Partner
  10. #185
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you change the ESC timing?
  11. #186
    Join Date
    Dec 2008
    Toronto, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Your best bet is to buy the programming card for $10 from HK. If you don't feel like waiting, download the manual and try to follow the arcane series of throttle commands to change the timing.
    But seriously, buy the programming card.
  12. #187
    Join Date
    Dec 2008
    Toronto, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    also, jmir, what C rating is your battery? 2200mah sounds pretty slim for the rig you are running. Remember that even if your battery is rated for 30C , that is a max capacity of 66amps. You don't want to be anywhere close to the max capacity of your battery. Once you have the ESC issue resolved, check the temp of your battery immediately after landing. If it is any warmer than a feverish forehead, you are taking risks with the longevity and stability of your lipos
  13. #188
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have an Eflite 60amp ESC. I don't think the HK programming card will work with that.
    I still don't know what you mean about ESC timing. Guess I better read up on it.
  14. #189
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: IdeaBeing
    I'm using 4-cell, 3000 mah, 20C battery packs with my Eratix. Plenty of power, unlimited verticals and approximately 12 to 13 minute flights. Cells do not get hot at all.
    I do have a couple of old 4S 2650 mah 30C that get quite warm now didn't before. So, I guess they are just getting old.
    I also have a 4S 2200 mah 30C that I use and get about 6 to 7 minute flights with plenty of power I also notice easier to hover mostly because of lighter weight.
    The Eratix is an awesome plane. Great 3D trainer.
  15. #190
    newjak's Avatar
    Join Date
    Nov 2006
    Cheswold, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jmir
    Here is a link to the manual. I must admit it can be confusing to program it using your TX but it can be done and the results are worth it.
    http://www.horizonhobby.com/ProdInfo...CInstSheet.pdf
  16. #191
    Join Date
    Jul 2003
    Grand Rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What the heck!! I have had a Eratix ordered from LHS for a month and a half. It has been delayed a few times since then. I see today on Horison's site it's now mid June!
    I purchased all the gear for it, everthing. What is comparable size etc, I know nothing close but what can I get now. Dealer said that all hobby products are hard to get because of back order situations. You would think it would be the other way around. Thanks.
    Dave
  17. #192
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Which timing did you use for the Eflite Power 32?
    Low, standard, or high?
  18. #193
    Join Date
    Dec 2008
    co clare, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i am thinking of byuing turnigy 4s 4000mah 20c battery is it good for this plane
    thankyou
  19. #194
    Join Date
    Dec 2008
    Toronto, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been using 4000mah 3S batteries with a turnigy 3548 motor, a reasonably light setup with excellent vertical performance. I need to keep the battery pretty far forward in order to balance the plane. I'd imagine you could easily get away with the 4S 4000mah, but remember that as you increase the weight, it's not about the power so much as it is about the wing loading. The Eratix is a really nice slow flyer with a very forgiving stall, but as you add weight, those characteristics will diminish, and the plane will need to fly faster to stay in the air. You will also increase the risk of aileron flutter, which these planes are notorious for at higher speeds.
    In short, if all-out 3D performance is your goal, go with the 4S but consider a smaller pack like a 3000mah to keep the wing loading low.
  20. #195
    Join Date
    Jul 2003
    Grand Rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well now it's mid July on arrival to the States. This is nuts. I bought an AJ Slick 55" and it's fantastic. More my type of plane. The dealers don't like it either believe me.
    Dave
  21. #196
    Join Date
    Jul 2005
    LondonSussex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: fiqa
    thankyou
    Yes it is. I've bought three for mine with a 42-50 650Kv motor with an APC 14x7 prop.
    The only issue is that it needs care to get it into the fuselage as the pack is wider where the wire exits.
    I've flown for ten minutes and not had to put half the capacity back into it when charging.
    The power with this setup is amazing and as far as weight and tip stalls are concerned, mine will easily fly at a walking pace.
  22. #197
    Join Date
    Apr 2005
    Laurinburg, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been using 4S 3000mah 20C with great results. The ones I use are the Blue-Lipo offered by hobbypartz.com for $29.70.
    I fly for 10 minutes and usually restore around 2600 mah back when charging.
  23. #198
    Join Date
    Oct 2004
    Auckland, SK, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can anyone suggest a motor which would run of 5cell 3300 lipo?This is not about me overpowering the plane and going stupid. I just happen to have two of these battereis from other planes I can use.
    Cheers
  24. #199
    Join Date
    Jun 2005
    Prescott Valley, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    try hobbyking.com. Look under their Turnigy outrunners.
  25. #200
    Join Date
    Jun 2009
    Burbank, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a note on Turnigy motors. One of them failed in my Eratix plane and I had to switch over to a Eflite 32. Lucky I was able to glide the plane in for a landing. Dealing with Hobby King is not easy since they are in China. The cost of shipping the motor back was not worth it. I hear they are opening a warehouse in the United States soon. I used a Turnigy 80 ESC and it worked fine with my Eflite 32 so the motor was the problem. But for safety I went with an Eflite 60 ESC and I even tested the Turnigy motor with the Eflite ESC and it still did not work right. I tossed the motor in the trash.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
