Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
Ultimate by E-Flite
Reply
Old 12-27-2008, 09:39 PM
Tomcat_104
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ultimate by E-Flite
My son got an E-Flite Ultimate for Christmas because his college doesn't allow "fossil fuel" planes in their dorms. Since this our first foray into electrics I, errr Santa decide that an E-Flite ARF with everything E-Flite was in order. Well we have just about finished the plane and just tested our motor out and we can't get it to work. The receiver is getting power and working and the servos n the wing, horiz and vert stabilzers. We can't determine if the problem n in our speed controller or our motor or simply the way we hooked everything up. We have checked and double-check most everything and since our LHS is closed now I have to ask you guys for help or suggestions.
What can we do in the meantime? Any help or suggestions would be appreciated.
David
Tomcat_104 is offline
Old 12-27-2008, 11:30 PM
patnchris
patnchris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ultimate by E-Flite
Some setups require the reversal on the throttle channel......Also make sure the throttle is off or the ESC will not arm....Pat
patnchris is offline
Old 12-28-2008, 04:59 AM
louisben36
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI, MAKE SURE YOU TAKE THE PROP OFF FIRST. ALSO, TO ADD TO PATNCHRIS`S COMMENT, MAKE SURE THE TRIM IS DOWN ENOUGH AS THIS CAN ACTIVATE THE SAFETY ON THE ESC TOO.
louisben36 is offline
Old 12-28-2008, 11:27 AM
normgoyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, have you mated the receiver to the transmitter, you have to get them working together, read your manual to find the sequence. Norm
normgoyer is offline
Old 12-28-2008, 06:35 PM
Tomcat_104
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of these were good suggestions, the ones I had not tried before so I tried them several times. Unfortunately none work, I'm beginning to think I have a faulty ESC. I borrowed a friends airplane (which flew successfully today) and my TX, RX and battery worked fine in it. Since his plane used a 20Amp controller and mine has a 40Amp I chose not to mix the two since I have no experience with electrics. Could I use the smaller motor with the 40Amp ESC?
When I first started up my plane I got 3 audible tones and then 3 more increasing tones plus a little "wiggle" out of the motor. That made me believe the motor was okay. Do you guys think that was a reasonable assumption?
I also am getting a lot of "chatter" or "flutter" from all of my servos. I know this is not good but I assumed it was related to my other trouble. This kind of reinforced my idea of a ESC problem.
I guess it's time for a trip to my LHS, thank you guys for all your help.
Reply
Display Modes
