Go Back  RCU Forums > Electric Aircraft Universe > Electric Aerobatic & Sport Planes
Reload this Page >
TOLEDO SPECIAL 40 ARF by Hangar 9
Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
Old 03-02-2011, 06:06 AM
  #101
papajeff
papajeff's Avatar
Default RE: TOLEDO SPECIAL 40 ARF by Hangar 9
Flying5150,
Having flown my TS many times, I really do not think that there is any need for flaperons. I fly on a grass field and my
TS tales off beautifully and lands with absolutely no problems whatsoever! With the Hangar 9 recommended set up,
I have plenty of power when neededand slowing down for a landing approach has never been an issue that I
thought would require flaperons. I hope that this helps you with your build andI would be interested in seeing any
photos of your build and Maiden flight. Videos, if possible, would also be appreciated.
ORIGINAL: flyingt5150
Hi all,
I am almost finished with my toledo special, and I am just wondering has anybody used flaperons on it. I would like to know of any good or bad tendencies with them.
thanks
Old 03-02-2011, 06:15 AM
  #102
papajeff
papajeff's Avatar
Thrawn,
Your setup soulds real good to me and don't hesitate to post some photos and video of your flights.
We all benefit from seeing how other Toledo Specials are built and flown.
ORIGINAL: thrawn150
Final setup and numbers: Lightning 50, Ice 75, 5000 mah 5S 25C lipo and 12 x 8 prop = 7 lbs 3 oz and 975 watts 50 amps at full power.
Old 03-02-2011, 06:36 AM
  #103
papajeff
papajeff's Avatar
I did use some of the control rod hardware that came with the Toledo, but I used Dubro metal clevises
for the alierons. When using the provided plastic clevis, you can see in the photo below that I put a small
piece of standard fuel tubing over the ends to prevent the clevis from opening. Just a little added protection.
ORIGINAL: kivisto
Hello everyone. Have a TS also an old (new in box saito 80) as well as a 100 twin, possible to mount the twin?? Not thrilled with the clevis choice, anyone subsituted another clevis?
ID:	1572222   Click image for larger version
ID:	1572223   Click image for larger version
ID:	1572224   Click image for larger version
Old 03-02-2011, 08:10 AM
  #104
thrawn150
I only got to fly it once before the weather turned. I did shoot video, but it turned out badly. The weather is just starting to get better; I hope to have the TS out with in a month. I am currently converting a H9 p-47 and that is eating all my hobby time. I thought the TS flow great, but I had the ailerons set wrong so way touchy.
Old 03-02-2011, 10:20 AM
  #105
Wyoming Cowboy
My Feedback: (13)
I have a Saito 65 on my Toledo & flaperons are almost essential...it came in pretty hot without them.  I'm sure performance is different depending on whether you're using E-power or glow.
Old 03-02-2011, 10:32 AM
  #106
flyingt5150
PAPAJEFF,
 Thanks for info on the flaperons.  I think I am going to try and using them. Were I fly it will help slow done the airplane.
I haven't had the chance to fly  my Toledo Special yet the glacier here has not melted.
Below are some links to a you tube videos where I fly, like to able to use the flaps if needed
thanks
http://www.youtube.com/watch?v=eupAe...eature=related
http://www.youtube.com/watch?v=d8CeebkUAdw
http://www.youtube.com/watch?v=gmez5...eature=related
Old 03-02-2011, 10:59 AM
  #107
papajeff
papajeff's Avatar
The Cowboy knows what he is talking about! I forgot, since I fly 99% electric power, that glow & gas power
is a much different animal from electric. I would take his suggestion to use flaperons.
quote]ORIGINAL: Wyoming Cowboy
[/quote]
Old 03-02-2011, 10:12 PM
  #108
R/C Gypsy
R/C Gypsy's Avatar
Hi Papa,
I do my TS a little different.....I found it to be very clean and not want to slow down to land........ Landing it a little fast wasn't a problem, it was getting to settle in and touch down.
It acts much like my warmliner .....so I use Spoileron on it, like the warmliner, and it lands just great........... No long glide, super stable( because your adding washout), and a deliberate, predictable desent.
I have two settings on my flap switch, 3/8" up aileron, for the approach, and 3/4" up for the final approach and touch down.....I flown many flights like this and prefer it to the flaperon set up, which seems to make it float.
Paul
Old 03-03-2011, 04:28 AM
  #109
papajeff
papajeff's Avatar
Paul,
For sure, your TS is definitely a little different from the stock setup that I have on my electric powered one.
Your Toledo has to be the best example of pure excellence that has ever been built! It is a real showpiece
and you fly it like the Master that you are! With your personal mods and your power system, your TSdoes
benefit from yourspoileron set up. (Am I prejudiced??????? You better believe it and just to substantiate
this fact, take a look at these photos of Paul's TS.)
NOTE: Photo #1 & #2 - custom square pattern underwing for orientation in flight.
Photo #3 - custom made rear wheel pant and lime green pin-striping.
Photo #4 - re-designed battery tray inside fuselage rather than in the nose.
Photo #5 - custom rear wheel pant
Photo #6 - cowl grill vent for cooling of the ESC & battery
Photo #7 - custom battery tray
Photo #8 - access to battery via custom hinging of windshield
Photo #9 - underwing custom pattern
Photo #10 - pin-striping ("Fly First Class" is right, for sure with Paul's TS mods!)
Photo #11 - Paul at the RCCR meeting giving a Demonstration with his Toledo
ID:	1572557   Click image for larger version
ID:	1572558   Click image for larger version
ID:	1572559   Click image for larger version
ID:	1572560   Click image for larger version
ID:	1572561   Click image for larger version
ID:	1572562   Click image for larger version
ID:	1572563   Click image for larger version
ID:	1572565   Click image for larger version
ID:	1572566   Click image for larger version
Old 03-03-2011, 05:25 AM
  #110
papajeff
papajeff's Avatar
5150,
Flying "T" Productions! I like it! Ohhhhhhhhhhhh............Yeahhhhhhhhhh!!!! Very nice videos
and I like your wing walker/sorta pilot! He reminds me of Batman's JOKER! LOL!
Old 03-03-2011, 06:47 AM
  #111
R/C Gypsy
R/C Gypsy's Avatar
Hi Again,
I'm sorry.......... I ment to say spoileron, not Flaperon...........Oh well, at least I got the explaination right!
I corrected the post
Paul
Old 03-14-2011, 02:02 PM
  #112
flyingt5150
Here are some photos of the finished Toledo Special. I haven't flown it yet, waiting for the weather to get better.
ID:	1578760   Click image for larger version
ID:	1578761   Click image for larger version
Old 03-14-2011, 02:18 PM
  #113
papajeff
papajeff's Avatar
"T"
NICE!!! I like the OZARK Air Lines sticker! It looks like you have more snow on the ground than we do.
Most of ours has melted, but it is still much too wet to start flying here. Please let us know when your
weather clears and you are about to Maiden your Toledo. Have someone take photos and mybe a video.
Best of luck with the Maiden.
Old 03-15-2011, 07:59 AM
  #114
thrawn150
got a stupid question, I am trying to take out the wrinkles in this planes stabilizer and not coming out. looks like it is just adhering to the balsa, but the bubbles remain. Using a H9 Iron set to 5. Would I be better to use a heat gun?
Old 03-15-2011, 11:00 AM
  #115
papajeff
papajeff's Avatar
I have found that my iron with a teflon foot has no problems getting the wrinkles to tighten. I do not use it with a
sock, but I don't know if you used a sock on yours. On some stubborn wrinkles, I do use an old hair blower on
MED setting and just take it easy and make sure that you move the blower back and forth over the wrinkle. I hope
this helps.
ORIGINAL: thrawn150
Old 04-13-2011, 10:39 AM
  #116
thrawn150
first flight of the year and only 2nd over all with this plane. This is a great flyer, with the lightning 50 and 5S plenty of power and lands like a dream. Allot of my club Mates were out today and really liked the look of it.
Old 04-13-2011, 11:11 AM
  #117
papajeff
papajeff's Avatar
Thrawn,
I'm pleased to hear that the first flight of the season with your Toledo went so well. It really looks good and it's flight
characteristics make it an enjoyable plane to fly. For your next flight, have one of your pals take some photos and be
sure to post them here.
Old 04-13-2011, 11:21 AM
  #118
thrawn150
papajeff
The only issue I have with this plane is the battery bay is a pain. I may try the cockpit idea you had later this season.
Old 04-13-2011, 11:31 AM
  #119
papajeff
papajeff's Avatar
Back on post #109, Paul came up with the mod to make the battery tray in the cockpit and have access thru the
front "window." For me, I never had a problem with the battery hatch and compartment under the nose, but Paul's
mod is a neat way to do it.
Old 04-22-2011, 10:53 AM
  #120
flyingt5150
I flew my Toledo Special early part of this week, and I couldn't be happier.  My four stroke OS FL70 ran excellent, and the airplane handeled the wind very well. The wind speed was about 10mph with gusts up to 15. I used the flaperons and that took some getting used to. Other than that I am very please with this airplane and engine. Here is a link to a video of some flights I had.
http://www.youtube.com/watch?v=tLvIkZmV_rQ
Old 04-23-2011, 05:51 AM
  #121
papajeff
papajeff's Avatar
"T"
What a great flying field you have! I am pleased to hear, and see, that you are enjoying your Toledo.
Old 04-29-2011, 08:54 PM
  #122
Carlos G
Carlos G's Avatar
Hi PapaJeff,
I got a T.S. for free, mainly because the previous owner crashed it and didnt want to bother with the repairs. Upon inspecting the plane, I found the control surfaces seem to be stiff. The hinges are the C.A. types and the control surfaces seem to be glued too close to the fixed stabilizers. Was this the way the T.S. came or are the hinges glued in by the purchaser? Either way it doesnt matter as I think I will have to remove the surfaces and re-hinge them. I am just curious about this.
For what ever its worth the area below the front windshield seems to be the weakest point of the plane. This is where most of the damage happened when the plane was dorked by the previous owner. Hangar 9 offers pretty good after the crash support with parts. should you need them. The only problem I found was trying to find the same thickness plywood to make some of the repairs. The vendor for Hangar 9 seems to be using some odd stuff.
This is what I have started with....
Keep the thread going!
Carlos G.
Old 05-03-2011, 06:13 PM
  #123
kivisto
My wife saw above werckage, thought it was the titanic strewn accross the ocean floor...... please keep rebuild posted
Old 05-06-2011, 07:26 AM
  #124
papajeff
papajeff's Avatar
Carlos,
The CA type hinges are installed by the builder(not by the factory)and I did not have any problem with the rudder, elevator
or aileron surfaces as I have a habit of folding the CA hinges, and working them back and forth many times,before installing
them. It looks like you have a bit of a re-build on your hands and like Kivisto said, please keep us informed of your progress
by posting your repairs. I am sure that all of us will be interestedin your re-build.
Old 05-09-2011, 07:14 PM
  #125
Carlos G
Carlos G's Avatar
Hi All,
Well I have been working on "Humpty-Dumpty" so to speak and have been slowly piecing all the small bit of ply back together. Luckily I was there when the crash happened. I helped previous owner gather up as many parts and bits of wood we could find thinking He was going to put it back together. As it turned out he was going to just trash it so I asked for the wreakage and now it's my problem.
I started by stripping back the covering to some solid wood and then slowly tack gluing the wood flakes back to the cabin. Like a jig-saw puzzle, I had to try and fit the small pieces of ply back together edge to jagged edge. I initially tacked glued because when putting something together like this, sometimes you realize you glued in something out of sequence and have to back track to fit a particular chunk of wood. When a piece is missing or totally creamed then it was time to make a piece that would fit into the puzzle.
The "plan" was to build up the cabin to a point where I could re-attach the fuselage to the nose section...
