Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
Not impressed with Great Planes Ultimate EP.....
Reply
Old 06-06-2010, 10:32 PM
cloud_master
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Not impressed with Great Planes Ultimate EP.....
Just took up the Ultimate for it's maiden voyage tonight. It has the stock recommended hardware from the first release. I flew it with a 2200Mah 25c 11.1v and the recommended RimFire 35-30-950kv. I also used the recommened APC SF11X3.8. I don't know if it's the prop, but this thing was a dog. Way too much engine braking when pulling the power back (I have the esc brake off) and not enough grunt at full power. I am going to try a regular electric APC 10X5 and see how it performs. I will also loose a little weight and try the recommended 20C 2100Mah next after the prop. Anyone have any experience rigging this plane for someone that is used to a little performance?
My other plane is the Patty Wagstaff 1/4 EX-300 with a G-45. I've mostly flown giant scale aerobats until my buddy got me into electrics. I don't mind the electrics, but i want it to perform. I see the new kits of the EP Ultimate have gone to the new .10 Rimfire, which is a 1250KV. That may be the ultimate answer (no pun intended), but i'd like to see if I can get my current hardware to perform better. Thanks for any input........
cloud_master is offline
Old 06-07-2010, 08:52 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Not impressed with Great Planes Ultimate EP.....
The only thing you're going to save by going to a 20C battery is a small amount of weight, MAYBE.
All things being equal, the 25C battery will spin the motor faster, due to its ability to hold a higher voltage under load. Odds are going to the 20C, performance will be worse.
Without changing anything else, the best way to get more power is a larger, or higher-pitched prop. The key is to not go too big, or you will overload the motor, ESC, and/or battery.
After that it's a matter of whether you want to buy a new motor or a new battery. A motor with a higher Kv rating will spin the prop faster and provide more power.
Alternatively, a higher-voltage (i.e. 4S) battery will also provide an increase in power. However, it will also increase weight more than a motor upgrade, and will require you to add an external BEC to the system.
Matt Kirsch is offline
Old 06-07-2010, 10:58 PM
cloud_master
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I picked up a couple new props today. A 10X5E, 10X7E, and a 11X5.5E. I checked the amp draw on all the props, and the 11X5.5E was holding about 18 amps. This was with the 2200mah 25C. The 10" props were 3 amps less. I may try an 11X7E if i can get one. Also, my buddy wants me to try a Hyperion 1800Mah 35C. He thinks that will do the trick. I don't know how many more amps will be drawn, but I believe the motor is good for 20amps continous........
