Recommended: motor,esc,battery for MQ-9 Reaper (NP)
MD
just wondering what you guys recommend on putting into this plane... im new to electirc and lipo stuff so i just want an idea on how to start off things. i always liked UAV's so i decided to with the Nitro planes Mq-9 reaper
http://www.nitroplanes.com/mq9.html
any suggestions will be helpful.
thank you
thank you
RE: Recommended: motor,esc,battery for MQ-9 Reaper (NP)
This is what I have. It works really well and had power to spare.
http://www.hobby-lobby.com/brushless_axi2826.htm
http://www.hobby-lobby.com/radial_mo..._1364_prd1.htm
I have two of these in parallel.
http://www.hobby-lobby.com/4_cell_14...64085_prd1.htm
If you get something that is the equivelant of a .46 nitro you will be fine.
I get over 9 minutes. I have no idea how long it is at full throttle for a whole flight. I use 100% at takeoff and initial; climb then throttle back to just about 60% My batteries don't even get warm.
AZ
Claw
I am building my Reaper now. I am installing a Turnigy T3648-850
and am using a 11x8.5 three bladed prop from HK. Amp draw at full throttle is 46A.
Hope this helps,
Neal
Hope this helps,
Neal
Hey guys im about to order the MQ-9 and im going to try to put a nitro motor either in it or off the back.
Do you guys think it will even work or even fit?
