Had in flight complete motor mount breakage on E-Flite Yak 54. No ground strike, no broken prop, just all four arms of the X mount separated at the bolts that hold the mount to the motor. Prop is perfectly balanced, and I cannot possibly see why this problem occured. Any one else?????
LA
RE: .
The material it is made out off is crap use the old one as a templet to make a new one out of aluminum stock plate off the same thickness or close to the same thickness. I did and it works great
