Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Help no elevator on my new eurofighter
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 02-15-2011, 07:19 AM
Flybri89
Default Help no elevator on my new eurofighter
Anyone have any idea's on mixing...... everything elseworks rudder.motor, aileronjust no up or down only. I have a new Spektrum dx-5 radio and reciever in it I also switched the mixing switch to on still nothing. Any idea's? Thanks
Old 02-15-2011, 05:52 PM
tacx
tacx's Avatar
Default RE: Help no elevator on my new eurofighter
I'm confused. You can not mix anything with a DX5 Transmitter? Need more info.
1. Do you have a DX5e transmitter?
2. Are you using a AR500 RX?
3. How do you have your servos set up and which servos do you have pluged into which channels?
Old 02-15-2011, 06:39 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
The DX5e has delta wing (elevon) mixing.
One elevon servo goes in the aileron channel. The other goes in the elevator channel.
I suspect you have the two elevon servos plugged into the two aileron connections on the AR500 receiver. That won't work.
HUGE HINT: If you can't get the elevons to go in the right direction, no matter how you change servo reversing, try swapping the aileron and elevator plugs at the receiver.
