HobbyKing Variable 6s charging problem
Hi Guys, Need your help,
Recently i purchased a Hobbyking Variable-6s charger and 2 nos Rhino 3 cell, 11.1V, 1050mAh, 20C sereies lipo battery packs.
Today I tried charging the battery pack after setting the voltage to 11.1v (3s) and current 1A. Also i selected the battery type as Lipo in the menu.
But when I start charging by pressing the enter key for more than 3 secs a error comes "Connection Break". I rechecked the wiring and connected and disconnected the wires but still the error keeps on coming. This is happening with both the battery packs.
I tried charging mode and balancing mode.
Any help from your side would be highly appreciated.
Mustafa
Mustafa
My Feedback: (325)
RE: HobbyKing Variable 6s charging problem
If the main charge lead is plugged in and the lead on the pack and the charge lead has continuity then there must be a problem with charger. My guess is the main lead is missing.
