FSK Spitfire
My Feedback: (12)
FSK Spitfire
Hi,
Just received this kit and need to know what type of glue "UHU-Por" is. Searched on Google and all I could determine was that it is some type of contact cement made for polystyrene. Any recommendations would be appreciated.
Chuck
Chuck
fsk spit
hi , for plastic to foam you can use zap oderless /for foam [carfully]and epoxy[foam to foam]wing and stab
plastic to plastic reg zap ,i put the spinner on whith
elmers stick all [like silicone] i used part of the plastic sheet and foam to laminate the forward battery bulkhead and another pieice of plasticon top of wing in battery area ,epoxy bulkhead in and stick alled bat in place,the bat must be securly mounted
or it can do a lot of damage in even a minor prang
might want to look at ezones review of this ac.
launched at3/4 throttle it will haul off ,do this at full throttle
and epect it to tourqe roll very fast to left and down ,
untill impact if you dont get off the power ,the gearbox shaft will
bend if you oops it whith any power on ,the magnetic hacth hold
down in review works great .good idea to leave cannon of
till a/c is dialed in ,great looking a/c when done
good luck
mike
good luck
mike
