Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
4th of July Special from Wowplanes
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 07-08-2011, 09:50 AM
wowplanes
Default 4th of July Special from Wowplanes
Hello guys,
Hope all my American friends had a wonderful 4th of July. I certianly did.
I had an idea to design something special for Independence Day and maiden it on July 4th. Well I ran out of time and it was not quite ready to fly, but it was good enough for a show & tell. So I took it to the club picnic on July 4th and here is a picture.
It is 102" span and is an original design. I wanted to make something big, easy to build, easy to fly, streamlined and low drag, and here is what came out.
I went about it somewhat differently this time. I had no idea of the final shape so I first built the wing, then tried several shapes for the fuselage in CAD until I liked one. I did the same for the tail.
The paint job is not finished yet. I think I will add some blue to the H.Stab and some design and color to the V-Stab too.
Would you like to see a build thread?
Fahim
Old 07-19-2011, 10:05 AM
wowplanes
Default RE: 4th of July Special from Wowplanes
The inspiration for this baby came from the recent 4th of July Independence Day. My plan was to maiden her on the 4th, but I simply ran out of time. However, I got her in shape for a show & tell, and picture taking, at our club's 4th of July picnic.
I started without any idea how the plane would turn out. I have always wanted to do an "original", I wanted something big, something that would look impressive in flight, something sleek and aerodynamic with low drag, something that would be aerobatic, something that would not be too complex to build.
One thing I learned very early, is that, an original is much more difficult to design as compared to a scale model. I had no 3-views, no pictures, and no truckloads of documention to go by. Everything had to be imagined and created from thin air. Of course I did use aeronautical engineering principles to arrive at the proportions of the model, and ensure that she will be a good flyer.
I started by building a constant chord wing, no dihedral, semi-symetrical airfoil, psuedo-Fowler flaps, and ailerons. The servos and pushrods were to be concealed. The wing span ended up at 102"
Here are some pictures of the build sequence.
Fahim
ID:	1637522   Click image for larger version
ID:	1637523   Click image for larger version
ID:	1637524   Click image for larger version
ID:	1637525   Click image for larger version
ID:	1637526   Click image for larger version
ID:	1637527   Click image for larger version
ID:	1637528   Click image for larger version
ID:	1637530   Click image for larger version
ID:	1637531   Click image for larger version
ID:	1637532   Click image for larger version
Old 07-19-2011, 10:06 AM
wowplanes
And here are the rest of the pictures
ID:	1637534   Click image for larger version
ID:	1637535   Click image for larger version
ID:	1637536   Click image for larger version
ID:	1637537   Click image for larger version
ID:	1637538   Click image for larger version
ID:	1637539   Click image for larger version
Old 07-19-2011, 02:44 PM
wattsup
Fahim, with all due respect, you just might be better off describing and building your original design in another forum here on RCU. As a suggestion, you might try the "Scratch Build" forum as a starting place. I believe most of us can appreciate your efforts but this particular RCU forum is about pattern planes, etc. Thanks for sharing, Everette
Old 07-19-2011, 03:54 PM
wowplanes
ORIGINAL: wattsup
Fahim, with all due respect, you just might be better off describing and building your original design in another forum here on RCU. As a suggestion, you might try the ''Scratch Build'' forum as a starting place. I believe most of us can appreciate your efforts but this particular RCU forum is about pattern planes, etc. Thanks for sharing, Everette
Excellent suggestion, Everette.
I could not find a "Scratch Build" forum, but the "Foamies! - RC Electric Foam Aircraft" forum would be better.
I am requesting the moderator to move this thread to the "Foamies! - RC Electric Foam Aircraft" forum, please.
Fahim
Old 07-21-2011, 06:35 PM
wowplanes
Well the forum moderator has not been in touch so I will continue here for now.
I continued with building the wing. A large 102" spam wing built as a one piece may be more than the average car or van can handle. There is no reason why it could not be built as a two piece wing. The mid wing can be permanently glued into the fuselage and the outter panels slid over carbon fiber or aluminum tube with dowels for registration. I have a van with a 12 ft bed, so I did not feel it necessary.
Fahim
ID:	1638375   Click image for larger version
ID:	1638376   Click image for larger version
ID:	1638377   Click image for larger version
ID:	1638378   Click image for larger version
ID:	1638379   Click image for larger version
ID:	1638380   Click image for larger version
ID:	1638381   Click image for larger version
ID:	1638383   Click image for larger version
ID:	1638384   Click image for larger version
ID:	1638385   Click image for larger version
Old 07-21-2011, 06:36 PM
wowplanes
....and some more.
ID:	1638387   Click image for larger version
ID:	1638388   Click image for larger version
ID:	1638389   Click image for larger version
ID:	1638390   Click image for larger version
ID:	1638391   Click image for larger version
ID:	1638392   Click image for larger version
ID:	1638393   Click image for larger version
Old 07-22-2011, 02:46 AM
jetmech43
My Feedback: (9)
Scratch Building, Aircraft Design, 3D/CAD try here
Old 07-25-2011, 03:42 PM
wowplanes
As I said earlier, I would like to have this thread moved to "Foamies! - RC Electric Foam Aircraft"
But how do I go about doing it? HELP
Fahim
Old 07-27-2011, 01:37 PM
wowplanes
Since I do not know how to move this thread and have not heard from anyone how it can be done, I guess I will continue here until then.
ID:	1640838   Click image for larger version
ID:	1640839   Click image for larger version
ID:	1640840   Click image for larger version
ID:	1640841   Click image for larger version
ID:	1640842   Click image for larger version
ID:	1640843   Click image for larger version
ID:	1640844   Click image for larger version
ID:	1640846   Click image for larger version
ID:	1640847   Click image for larger version
ID:	1640848   Click image for larger version
Old 07-27-2011, 01:38 PM
wowplanes
...and one more
Old 07-30-2011, 03:52 PM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Thread moved from:  All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft
Old 07-31-2011, 10:30 AM
wowplanes
Well, it is time to start building the fuselage. It comes in 4 parts, 3 of which make the fuselage and the 4th one makes the cowl.
Fahim
ID:	1642441   Click image for larger version
ID:	1642442   Click image for larger version
ID:	1642443   Click image for larger version
ID:	1642444   Click image for larger version
ID:	1642445   Click image for larger version
ID:	1642446   Click image for larger version
ID:	1642447   Click image for larger version
ID:	1642449   Click image for larger version
ID:	1642450   Click image for larger version
Old 07-31-2011, 06:01 PM
Gohmer
ORIGINAL: wowplanes
Hello guys,
It is 102'' span and is an original design. I wanted to make something big, easy to build, easy to fly, streamlined and low drag, and here is what came out.
Fahim
No. Foam airplane?
Old 08-01-2011, 04:26 AM
wowplanes
Its a composite of balsa-ply-foam-LSII
Old 08-04-2011, 06:32 PM
wowplanes
I continued with building teh fuselage. Some of the pictures are not in sequence and were taken after the final paint, but I hope you will get the idea.
Fahim
ID:	1644398   Click image for larger version
ID:	1644399   Click image for larger version
ID:	1644400   Click image for larger version
ID:	1644401   Click image for larger version
ID:	1644402   Click image for larger version
ID:	1644403   Click image for larger version
ID:	1644404   Click image for larger version
ID:	1644406   Click image for larger version
ID:	1644407   Click image for larger version
ID:	1644408   Click image for larger version
Old 08-04-2011, 06:34 PM
wowplanes
.... and a few more
ID:	1644411   Click image for larger version
ID:	1644412   Click image for larger version
ID:	1644413   Click image for larger version
ID:	1644414   Click image for larger version
Old 08-05-2011, 08:26 AM
wowplanes
I forgot to show how the wing is mounted to the fuselage. This should be done before the LSII and final painting stage. Here is build sequence for mounting the wing.
Fahim
ID:	1644608   Click image for larger version
ID:	1644609   Click image for larger version
ID:	1644610   Click image for larger version
ID:	1644611   Click image for larger version
ID:	1644612   Click image for larger version
ID:	1644613   Click image for larger version
ID:	1644614   Click image for larger version
ID:	1644616   Click image for larger version
ID:	1644617   Click image for larger version
ID:	1644618   Click image for larger version
Old 08-05-2011, 08:27 AM
wowplanes
...and some more
ID:	1644620   Click image for larger version
ID:	1644621   Click image for larger version
ID:	1644622   Click image for larger version
Old 08-10-2011, 08:19 AM
wowplanes
Itis time to start working on the tail. The construction is pretty simple as you will see from the pictures..
Fahim
ID:	1647027   Click image for larger version
ID:	1647028   Click image for larger version
ID:	1647029   Click image for larger version
ID:	1647030   Click image for larger version
ID:	1647031   Click image for larger version
ID:	1647032   Click image for larger version
ID:	1647033   Click image for larger version
ID:	1647035   Click image for larger version
ID:	1647036   Click image for larger version
ID:	1647037   Click image for larger version
Old 08-10-2011, 08:20 AM
wowplanes
...and one more
Old 08-11-2011, 05:38 AM
wowplanes
And now the Vertical Stab and rudder.
ID:	1647424   Click image for larger version
ID:	1647425   Click image for larger version
ID:	1647426   Click image for larger version
ID:	1647427   Click image for larger version
ID:	1647428   Click image for larger version
ID:	1647429   Click image for larger version
ID:	1647430   Click image for larger version
ID:	1647432   Click image for larger version
ID:	1647433   Click image for larger version
ID:	1647434   Click image for larger version
Old 08-11-2011, 05:39 AM
wowplanes
... and a few more pics.
ID:	1647436   Click image for larger version
ID:	1647437   Click image for larger version
Old 08-12-2011, 07:54 AM
wowplanes
I painted the fuselage and tail feathers. Next I mounted the H & V Stab feeding the servo cables into the fuselage.
ID:	1647900   Click image for larger version
ID:	1647901   Click image for larger version
Old 08-15-2011, 07:28 AM
wowplanes
It was time to fit the main gearand tail wheel. I had imbedded plywood pieces in the wing to secure the mains, but had forgotton to install blind nuts, so I had to resort to threaded inserts. The main gear was from a 1/3 scale CAP, but it was sitting too high, so I had to cut the struts down some and repaint them while to match the color scheme.
Fahim
ID:	1649011   Click image for larger version
ID:	1649012   Click image for larger version
ID:	1649013   Click image for larger version
ID:	1649014   Click image for larger version
ID:	1649015   Click image for larger version
ID:	1649016   Click image for larger version
