Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
trying to land a pylon plane
Reply
Old 07-26-2011, 07:36 AM
chrisfox
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default trying to land a pylon plane
Im in need of some input been flying 17 years in the past year thought I would try a pylon plane started out with a switch blade then a rifle and now a voodoo and also a sunracer i am having problems landing not sure if I should ute flaps or spoilerons does anyone have any input on what I should be using?
chrisfox is offline
Old 07-26-2011, 06:43 PM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: trying to land a pylon plane
Try to come in shallow ... as you are flying the downwind leg, keep her low and DO NOT dive. Even with throttle off, she will pick up speed if you dive her. I like to keep the throttle on like a 'low idle' as it will create some drag. Turn slowly for the base leg and for the approach, gradualy losing heigh without diving. Then for the approach you can bring her in as low as you can and if she is still fast, raise the nose a bit, kinda like a porpoising effect to bleed speed. Might your field be kinda small?
tIANci is offline
Old 07-26-2011, 07:24 PM
chrisfox
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No its not small I thought if I used flaps or spoilerons it would help slow me down
chrisfox is offline
Old 07-26-2011, 11:21 PM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try to check your CG too ... a nose heavy plane will come in hotter ...
tIANci is offline
