Spektrum Dx6i charger question
Hi,
I have a Dx6i with the charger but the little adapter that insets into the TX is missing and Horizon doesn't sell them without the charger. I wondered if I could cut a plug end off a old ac adapter and solder it on. Does anyone have info or tips on how to do this and if it will work? Thanks
FL
RE: Spektrum Dx6i charger question
Ditto what Walt said, Spektrum runs backwards from what most use. The center pin is NEGATIVE, the outer ring is POSITIVE. Look right on the wall wart, mine both have the diagram for the plug right on them.
