ubec and rx pack - at the same time?
can i power my rx with ubec set at 5v and also plug a 4cell NIMH (4.8v) battery at the same time?.. thanks
My Feedback: (16)
RE: ubec and rx pack - at the same time?
I would not do that if I were you. If you use both at the same time a brownout can occur especially if you're using Spektrum gear. I lost a plane that way on maiden day. Bad idea!!!
ORIGINAL: khymlawrence
Not a good idea, one or the other will almost always be at a different potential than the other one is which can cause all sorts of problems. Now, if you used a 5 cell battery pack and isolated both from the bus with a diode, you could safely have them both connected as then only the higher voltage would be powering the bus. Still not a good idea as the diodes would have to handle the maximum current ever drawn, would add complexity and be another source for failure.
My Feedback: (16)
ORIGINAL: Rodney
