ducted motor help
MD
RE: ducted motor help
its a plane that has a 57" wing is 77" fuse nd the plans call 4 a O.S. .91 ducted fan engine nd Dynamx fan unit....i want 2 convert 2 electric nd since the rpm high end 4 the O.S. puts out that number in the previous post i figured i needed a electric that puts out the same
TN
I'd post over here: http://www.rcgroups.com/electric-duc...n-jet-talk-12/... the gurus will sort it out for you.
The OS 91 for ducted fans develops 3.7hp at 22000 rpm.
To match that power (3500W) you will need some serious electrics, rather more than just "what motor will I need?".
Unless you have quite some experience in this field I would aim for something that required a good bit less power.
MD
i wanna thank you 4 ur help nd input nd i have several jets already in my hanger nd this 1 is just the next step up i only needed help cause fo the convertion issue but i will keep u informed of my progress
Check out Xreme Power Systems. They sell Dynamax fans already modofoed for electric so it'll pretty much be a drop-in replacement for your Dynamax/OS combo. I recommend contacting them with the size and weight info on your jet and they can recommend a fan/motor/battery/esc combination.
Rob
http://www.xtremepowersystems.net/products.php?cat=33
Rob
