Spray Paint For Foam Planes?
Does anyone know where to get this "foam safe" paint and what brand and type should I be looking for?
I'm in the process of building a GWS P-51 and did some sanding work and would like to paint over the repaired area.
Thanks!
Thanks!
Hey Daff, I was looking for the same thing and tried many types of canned spray paint, even though I was told that "Krylon" won't eat the foam, it does (and fast!) So after no luck with the canned type, I ended up buying an airbrush (Testors) and I use the Testors water based acylic enamel. It really works great, also with an airbrush you can use any (acyrlic) paints you can get your hands on, just thin it out with water a little and your set.
Scott
Scott
