Set up for two 4 cell Lipos
I have a Top flight P 51 60 and i am going to run some kind of electric motor. I would prefer to stay with a 6 cell with an E flight 90 but not sure if it will work good . What is needed to run two four cell lipos so i will have the equivalent of 8 cells.
RE: Set up for two 4 cell Lipos
A "Y" connector and an ESC that will handle 8s batteries.
The 90 on 6s running a 18X6 4 blade prop gives about 11 plus pounds of thrust. using a 20X8 2 bladed gives about 13.5 pounds of thrust.
Here is the calc program I used
http://www.s4a.ch/eflight/motorcalc_e.htm
http://www.zingerpropeller.com/4_bladed_propeller.htm
Buzz.
Buzz.
HAHAHAHHA I need to proof read more. Some how or another I did not add the link and the (series) I put after the "Y" is missing.
New hours at work, thats my story and I am sticking to it.
Depending on your connectors.
http://www.hobbyking.com/hobbyking/s...dProduct=17633
http://www.hobbyking.com/hobbyking/s...dProduct=18603
https://www.leaderhobby.com/product....=9394001220589
Buzz.
Buzz.
WI
I run 2 4cell 5000 mah packs in series with an E-flite power 90 motor and a 16x10 e prop in my Venus II. Makes 1800 watts and my plane weighs 9.5 lbs. Great top speed and vertical performance. You could definately use this set up in your bird.
