Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
hobbyking t-28 funfighter
Old 06-08-2012, 11:43 AM
jon myers
Default hobbyking t-28 funfighter
The manual reccomends a cg of 50 mm from the wing root. The video that HK put out reccomends a cg of the first set of panel lines using a 3 cell 1000 pack. Which is correct? Any experience you have had would be appreciated.
Old 06-22-2012, 10:40 AM
WaffleMan
WaffleMan's Avatar
Default RE: hobbyking t-28 funfighter
If the video shows the same plane flying at that cg, than the video is correct. Besides, I would rather listen to somebody who flys the model than whoeer writes the manuel for these things.
Old 06-22-2012, 10:49 AM
jon myers
Thank you for the advice. I will go with the reccomendation on the video.
