Power pod to get glider up
TX
Anyone use a power pod on their glider to get it in the air? What engine do you use, how big is the glider you use the power pod with?
Goldberg makes (made?) a power pod to fit the Gentle Lady. I used one, but it's a large thing adding drag. It's better to put the motor stuff in the fuselage, if you're thinking electric.
I've seen a few wet powered planes with add-on pods which work well.
Basically the guys just mount the motor with sufficient prop clearance over the wing on a stiff pylon. For .09-.15 motors two strut work better than one.
