Swamp Cooler For Li-Poly
Useing .125 sq alu tubeing from hobby shop glue sq tube
to one side of the battery. Stacking batterys on top of each
other. Ten cut blue shop towel 1" wide X 3" long slipping
cut pices folded in half between cells with air gap and spray with icewater I have used this metod about 4 yrs on Ion's they hot also
Loctite has made a insulating thermo conductive exposie call output for mounting transistors for about 15yrs now. small thin alu will add more thermo radation as well as weight to the alu sq's also you can solder to alu with All-State Duzall Solder kit AL509 from a welding shop. But the blue shop towel weighs only 1/2 oz. CU
