ESC application
AR
ESC application
If I have a motor that is recommended to use a 40 amp ESC and I put a 60 amp ESC in the vehicle, will any harm be done to anything in the plane? In other words, is overkill in an ESC going to damage anything?
RE: ESC application
ORIGINAL: JollyPopper
Hope this helps.
TN
RE: ESC application
ESCs only allow through the current demanded by the motor and prop.. a larger ESC cannot force the motor to draw more current. You could put a 10A ESC or a 200A ESC on a motor propped to draw 10A... and with either ESC the motor/prop would only draw 10A.
