Falcon 120 help
Falcon 120 help
I have afalcon120 from nitroplanes and I was wanting to do a dual EDFsetup, I was wondering if dual 70mm running on a 6s would work? My friend said it would but yet no one else has tried this ( as far as I can see) -Outside Diameter : 71mm -Material:Carbon Fibre Reinforced Nylon (Whole Unit) - Rotor DIameter : 68mm,4blades -Max RPM:50000 RPM - Motor Shaft : 3.0mm & 4.0mm -Working Voltage : 11.1v - 22.2v (3 - 6S ) - Motors required :Inrunner & OutrunnerBrushless Motor2500 - 4300Kv Hide Signatures | |
RE: Falcon 120 help
