If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2005
    summit, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Help with ESC
    This is a general question about ESC'S Once you initially calibrate the throttle, can you delete the setting and start over. I see nothing in instruction sheet about recalibrating throttle. I do see info about resetting to factory settings but nothing about throttle calibration after initially setting. Thanks Dave
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help with ESC
    It's going to depend on the specific esc. Any of them that can calibrate throttle range can be "re calibrated" later. There are others that have no calibration and then there are others that calibrate at every power up. There's probably more types than those too.
    The only thing I don't know about is "deleting"
    and airplanes were in
  3. #3
    Glacier Girl's Avatar
    Join Date
    Jul 2004
    Lakeland, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help with ESC
    I've had a few esc's that you could set the calibration every time you powered them up. And not a good thing at times. If the throttle stick wasn't in the fully off position when the esc was powered up that position became the new off. Put the stick to the bottom and then start to move it up and nothing would happen till you passed that spot.
    Easily corrected by unplugging the esc, then recalibrating it.
    Missing Man Formation, Looking heavenward you can't help but shed a tear, mournful, lonesome, a hole that screams out at you.
    P-38 Lightning Brotherhood #75
  4. #4
    Join Date
    Apr 2004
    Colchester, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help with ESC
    I must have half a dozen ESCs from a variety of manufacturers and they all calibrate their throttle settings in the same manner. (Remember that Futaba use a reverse throttle signal). The procedure can be repeated as many times as you like, effectively deleting the previous setting.
    1. ESC off, TX on with throttle at max setting.
    2. Power ESC, ESC beeps, quickly move throttle stick on TX to minimum, ESC beeps again, throttle range set.
    If the ESC is ever powered up with the throttle stick above previously set minimum, ESC will beep continuously and motor will not arm - moving the throttle trim up accidentally can cause this.
    Don't forget to have the model securely fixed down and keep fingers well away from prop when setting the ESC. Mistakes are easily made and it's no joke to have a model start up when you're not expecting it (ouch!).
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
