Can you put an ECS and a 2.4ghz reciever next to each other?
CA
I asked this in the ARF section but got no response except to maybe post it here for a better response. So here goes..........In assembling my Cermark Cosmos I've ran into a space problem. The rudder and elevator servos can't fit side by side because then the arms would have to be very short to fit in the fuse. If I add another rail I can put one in front of the other. With that problem solved it creates another. The battery cannot slide in and out of the compartment without removing the receiver every time and even then the receiver would set up against the battery. I could locate the receiver under the battery compartment but then it would be right next to the ESC? Which would be better? skeeter
I have been told I should not put anything near my ESC or UBEC. Well I never listen to many people so, I, for many many years flew my Cypher helicopter with my 72mhz Rx strapped on top of the ESC. Never had a issue. I now have a 2.4 Rx in the same place for over a year and many many flights with out a glitch.
Buzz.
Buzz.
