Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Sukhoi 29mm trying to crash
Reply
Old 07-31-2015, 08:23 AM
dragonsbear
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sukhoi 29mm trying to crash
I have flown this plane 4 times. The first was great and the Safe system worked. The second time was also flying well but ended in a crash when a large dog hit me. The crash took out the prop and landing gear. It hit a parking lot bumper flat and moving forward. It has a new fuselage and prop but nothing else has changed. The problem was on flight 3, 5 feet off the ground it went full down elevator and almost crashed. Tried again with the same results. Took it home, totally rebound and programmed it. 4th flight was looking good until the second circuit and it went full down. Recovered, backed off throttle and turned final to land. Went full down again. When holding the plane after it initializes, I leveled it out, then slightly up...few seconds later, full down.
No loose connections of any kind. Rebinding and programming isn't helping.
Any ideas????? only option is to put in a stock receiver at this point.
On a side note, when everything is working, it flies awesome!!!!
dragonsbear is offline
Old 07-31-2015, 04:03 PM
simpliciter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could be a bad servo
simpliciter is offline
