Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
disarming throttle with radio switch on electric plane?
Reply
Old 09-07-2015, 02:50 PM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default disarming throttle with radio switch on electric plane?
I have a JR 9303 radio and I saw a man at the flying field disarm his throttle on his electric plane. He used the gear switch on his spectrum 8 radio. I asked him if I could do that with my 9303 and he said I might could, but was unsure. Does anyone know if that would work with my radio? I looked at my manual and could not find anything about doing that.Thanks waynem
waynem is offline
Old 09-07-2015, 03:18 PM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Throttle hold or throttle cut. It can be done on the 9303.
One way is to set up a mix:
Pmix #5
THRO -> THRO
Pos 0 0%/0%
Pos 1 -100%/-100%
Offset -200
AIL POS0
GER POS0
RUD POS0
MMIX POS1
THR STK INH
Another way is In the System TRIM SET menu set the throttle to 0%.
In the Function list THRO CURV menu highlight Pos.0 under [THRO CURV] and set it to Pos.1
Highlight SW SELECT and set MIX to Pos1
Go to Point-3 highlight it and set it to 0.0%
Go to Point-H highlight it and set it 0.0%
flyinwalenda is offline
Old 09-07-2015, 03:22 PM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Brian, I will try it tonight.Wayne ---Hi Brian, I tried it and I cant get it to work.I have pos. 1 set to 0%-0% and pos.2 set to -100%- 100% and offset at-200 the only differance I see is mine says thro-Rthro and I cant change that. I will try the thro-curve tomorrow. Thanks again Wayne
waynem is offline
Old 09-07-2015, 07:03 PM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried the trim step in thro curve and I am looking at the monitor instead of trying the plane and I can stop the left thro from working but not the right one. I cant figure out what I am doing wrong. I will try the plane armed tomorrow and see what happens. Thanks Wayne
waynem is offline
Old 09-08-2015, 06:55 AM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Brian, I finally got it to work, I had to do what you said to both thro. and right thro. to get mine to work. I worked while looking back to monitor to see if they were both moving, Then I tried the plane and it worked. Thanks for your help. Wayne Mayes
waynem is offline
Old 09-08-2015, 03:45 PM
flyinwalenda
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wayne,
Yes I should have stated both sides of the throttle. Glad you figured it out !
Old 09-09-2015, 07:40 AM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem, Brian. I am a little slow with electronics. I never would have got it to work without your help. Thanks again, waynem.
waynem is offline
