Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Servo control with Raspberry Pi
Reply
Old 09-14-2015, 02:15 PM
Trettman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo control with Raspberry Pi
Hello!
I'm trying to control a servo with a Raspberry Pi using a library called piblaster.js which enables PWM on some GPIO pins, but for some reason it doesn't work. I can use piblaster to change the brightness of a LED, but when I connect the pin to the signal wire of the servo it always go to the same position, even though I change the value of the PWM.
Does anyone have any ideas of what I'm doing wrong?
Thanks!
Trettman is offline
Old 09-15-2015, 06:11 AM
Trettman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe I should add a bit more info, I was tired when I posted so I probably left some things out.
I've attached a picture showing how I connected everything. The servo worked when I used a transmitter and a receiver, but when I used the Raspberry Pi it did not. I tried with another type of servo (a Futaba S3003) but it didn't work either. I've seen other people use piblaster to control servos but for some reason it doesn't work.
Here's some short javascript code showing how I used the GPIO pin:
var piblaster = require("pi-blaster.js");
piblaster.setPwm(17, );
Trettman is offline
