To get 12s 44.4v just add the 2 + leads together and the - 2 together
Hi, I'm brain dead today. So if I add the 2 POS leads together and the 2 neg together using 2x6S 5000mah Lipo batteries . Do I get 12s 44.4volts but still only 5000mah?? a 6s lipo battery is 22.2 volts.
Am I right or not.
John
No, I'm wrong. pos to neg to pos. having Neg and Pos lead from 2 6S Lipo batteries will give you a 12 s battery but only 5000mah.
John
Am I right or not.
John
John
If you connect plus to plus and minus to minus you still have 6s 22.2v but instead of 5000 mah you have 10,000 mah... If you connect in seties - minus to plus you will have 12s but "only" 5000 mah
