Beast 60e power setup???
Here is the data from my new Beast 60e
Emaxx gt4030/06 420kv
Castle Phoenix Edge 75 esc
Xoar 17x8 PJN elctric prop
Nano-Tech 6s 4000 mah 45-70c battery on full charge
... This was the first static test and I was surpised by how hard it pulled. The build shouild end up around 9 pounds. I will be using an ar9120 power safe received and twinn Life batteries.
Wing servos are Spektrum 5040 metal gear digital and tail will be Hs-5645MG Hitech. I was going to use a Talon 90 but really like the data logging and safety kill plug on the Phoenix edge. What do you guys think about the 75? Is it big enough?
