Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Multi engine speed controls - fixed wing or copter - how do you control them?
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Reply
Old 09-19-2017, 09:12 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool Multi engine speed controls - fixed wing or copter - how do you control them?
My electric aircraft are all fixed wing single engine. I don't fly drones and I don't fly twin engine planes.
You can certainly connect two motors to the same ESC if it will handle the amperage, but then you may have synchronization issues between them. This worked fine in the days of brushed motors but I don't think brushless motors will work well with this set-up.
You can can certainly have two motors with two ESC but how do you sync those? Do you put them on the same channel or do you put them on separate channels? How difficult are these to synch?
And what about things like quads where you are actually using motor speed to steer and maneuver. How are you control these?
Just seems like an interesting topic for a discussion
aeajr is offline
Old 09-19-2017, 11:29 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With twin engine plankers, matched motors, esc's and props work fine. With multi rotor craft, the control of the motors is provided by the flight controller. Without the flight controller, it would not be possible to fly multicopters. The "pilot" only tells it to climb, go forwards, backwards, or left and right. Amazing tech in these things
Pete
pilotpete2 is offline
Old 09-19-2017, 02:10 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depending on the radio you can run a twin on something like a Dx-18 with special programming for multi engines by plugging each ESC into its own channel.
If you're using one of the onboard BEC's you have to pull the red wire from the other one. You can also just program them individually and then connect them to a y harness.
BarracudaHockey is online now
