Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
MOSFET on/off switch
Reply
Old 11-02-2017, 07:03 PM
rwh100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MOSFET on/off switch
Here is a design for a very capable semiconductor on/off switch that can be built DYI and used with LiPos from 2s to 8s. Rated for 50 A continuous and 180 A peak.
Attached Thumbnails On-Off Switch Rev 2.pdf
rwh100 is offline
Old 11-03-2017, 03:48 PM
jim billings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't find a supplier with the DigiKey part number for the mosfet. Where did you purchase yours? I'll order from them if possible.
Jim B.
jim billings is offline
Old 11-03-2017, 05:08 PM
rwh100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ordered them from DigiKey. P/N IPB180N04S400ATMA1CT
I just checked and they have plenty of stock. Try cutting and pasting the text from the line above into the DigiKey search entry.
FYI: There are no Os in the part number, only zeros.
Let me know how that works...
rwh100 is offline
Old 11-03-2017, 07:27 PM
jim billings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Works fine! I had used a 1 (one) as the first character, not an I (eye?). Three on order and thanks a lot!
Jim
Old 11-04-2017, 09:39 AM
rwh100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem. Let me know if you need any other information.
,,, and I'd like to see your results!
rwh100 is offline
Old 11-04-2017, 04:36 PM
Jennifer Curtis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use a double pole switch for reliability, particularly
if you use the ESC to power the receiver.
Slide switches wipe themselves and may be
more reliable. Some toggle switches also wipe,
but some to not. You need to sacrifice one to
find out (take it apart to see how it works).
When the switch is on, this circuit will consume
1.5 mA from a 6s battery or 0.26 mA from a
3s battery. Its not a lot, but for a small battery
it could be important.
At 50 amps, the mosfet will dissipate 2.5 watts
of energy as heat, getting slightly warm. At 180
amps it will dissipate 31 watts, so it will get hot
very quickly. Peak current this high should be
VERY brief.
Jenny
Jennifer Curtis is offline
Old 11-04-2017, 05:17 PM
jim billings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Jenny (and RWH100.) My background is Electronics Engineer so I fully understand your advice. If I can help in any way (well - - - you know.)
jim
Old 11-08-2017, 06:34 PM
jim billings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is my version of your gadget (I use the XT60 connectors on all my planes.) This is the second one I built after building the first and testing it. Works fine and I don't need to build arming plugs/sockets to turn everything on, just a little bitty switch.
Thanks for publishing your design.
Jim B.
ID:	2244170   Click image for larger version
Old 11-09-2017, 09:13 AM
rwh100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's great, thanks for posting your results. Spread the word! Make e-planes spark free, safer, and more convenient for all.
My hope is that technically inclined club members would make more of these at cost to share with others.
rwh100 is offline
Old 12-14-2017, 11:16 AM
rwh100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you used your MOSFET power switch at the field? Does anyone else want to build one?
Just curious..
rwh100 is offline
Old 07-19-2018, 11:42 AM
jim billings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's been a while but I've had a chance to make several flights with your Mosfet switch. Operation was flawless, a couple of landings were not. I now have parts for five more switches for the rest of my planes.
